Results 1 to 4 of 4
    Default Wireless keeps disconnecting on Note 8.0 with 4.2.2
    Ever since I upgraded to 4.2.2 Jelly Bean on my Note 8.0, the unit keeps disconnecting and reconnecting the wifi which interrupts any app installs or downloads. It does this on multiple wireless networks at different locations (home, work, restaurant, etc.). I have tried a factory default reset but that didn't fix the problem. Has anyone else had this problem and how did you fix it? Thanks.
  2. #2
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Carrier
    ATT SE 1.0
    Default Re: Wireless keeps disconnecting on Note 8.0 with 4.2.2
    Note 2 wifi issues here as well. Keeps saying internet unstable. You can try different options in the wifi advanced window.
    Sent via Tapatalk using Galaxy Note 2
  3. #3
    I'm having the same issue, sometimes the tablet will hold connection but often the signal is continuously dropped and picked up.
    I've done many router restarts and was contemplating a factory reset however since you say it has not fixed anything I'm even more confused.
    Any one else have any ideas?
  4. #4
    I have the same problem on Vero A8860 with Android jeallybean 4.2.2.
    I have also tries the factory reset by did not solve the problem.
    Still can't connect to any wi-fi
  1. Replies: 9
    Last Post: 03-26-2014, 09:31 PM
  2. Email Ringtone on GS II Skyrocket
    By SpringCTIL in forum Samsung Galaxy S II Skyrocket
    Last Post: 02-13-2014, 03:15 PM
  3. Problem with epub file
    By hellsbells1978 in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-28-2014, 04:40 PM
  4. Help with my Samsung Galaxy 4G
    By Dawn Perkins in forum Samsung Galaxy S4
    Last Post: 01-28-2014, 11:42 AM
  5. when is kitkat out on vodaphone
    By sjsmith1708 in forum Samsung Galaxy S4
    Last Post: 01-28-2014, 07:04 AM
