1. Scott McClure's Avatar
    I have a Samsung Galaxy Note 8 16gig wifi version
    1. Why root my note 8? What are the benefits and drawbacks?
    2. How do i root and what is the easiest way?
    3. What are some of the better free apps to download. There are articles on this topic online but the users of this product know better.
    03-08-2014 07:25 PM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    Rooting does open more doors for customizing your device. To borrow from the cliche, 'With great power comes great responsibility'. Once rooted, you will not be able to accept OTA updates, your warranty is void. Rooting does compromise the security of your device (you are taking advantage of a vulnerability in the OS)
    I would read this over a few times: Rooting - is it for me? Some Q&A | Android Central
    03-09-2014 10:22 AM
  3. Scott McClure's Avatar
    thanks for the response. I am also hearing concerns about battery life what can we do about this?
    03-09-2014 10:41 AM
  4. Golfdriver97's Avatar
    After rooting? I personally have a little better battery life, but that also depends on which device. my Samsung's improved because I needed to root to fully disable TW bloatware.
    03-09-2014 11:30 AM
  5. Scott McClure's Avatar
    thanks for into, i have been looking at the hard class protectors or glass like for the screen but im wondering if i get one what kind of case can i get that still fits it?
    Also what are the best accessories for the 8?
    03-09-2014 11:46 AM
  6. Golfdriver97's Avatar
    Often there are cases specifically built for devices. I would stick to those. My tablet I have a screen protector on and just a carrying case.
    03-09-2014 01:29 PM
  1. 128gb microSDXC card works on the Note 3!
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 02-17-2017, 08:02 AM
  2. Best custom ROMs for Sony Xperia U
    By silentghost1979 in forum Sony Xperia U
    Last Post: 09-27-2014, 02:48 AM
  3. Multi window on my Galaxy S 4 Active doesn't work ...
    By jpinto in forum Samsung Galaxy S4 Active
    Last Post: 03-18-2014, 12:18 AM
