Results 1 to 5 of 5
    Default Strange WiFi Problem
    My Note 8.0 worked just fine when we went away for a week. It worked while away. Upon returning home it would show as connected but nothing would come down. After going through numerous troubleshooting items I was ready to give up. We went to a restaurant with WiFi and I tried it worked just great but on home WiFi it just connects and nothing. At home I have another 8.0, Nexus 7, Note 12.1 and two Macbooks all work fine on home WiFi. Called Samsung & Time Warner Neither had any idea.
    I have done 3 factory resets all no help still won't connect at home. Went to Dr's office today and connected right away. I guess that I'll have to move? Anyone have any idea for a fix?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Strange WiFi Problem
    Quote Originally Posted by bobng View Post
    Have you reset the WiFi router? If not, consider that as your next move and see if there is a connection with the Note 8.0 - if not, check to make sure the device is fully updated.
    Thanks for your response. I have reset the router. Time Warner even ran tests on it. The software is up to date until Kit Kat is available. I guess that I'll have to go somewhere to install it.
  4. #4
    Are all your other connected devices working fine on the home router (especially the other note 8)? If not, it might be your router going south in a manner such that a simple reset doesn't resolve it.
    Sent from my SPH-L720 using AC Forums mobile app
    You hit the nail on the head. All my other units including the Note 8 were working fine. I swapped out my router at Time Warner and they are all working just fine. I guess that Note 8 just stopped working with that router. Thanks for the response!
  1. Strange... Cannot get Pictures into Gallery?
    By LowIQ in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-20-2014, 03:54 AM
  2. Problem w/ Audio...scratchy, tinny & "S" Has a Lisp
    By monicakm in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 05-20-2014, 03:27 AM
  3. New phone - first problem
    By Kibbster in forum HTC One M8
    Last Post: 05-19-2014, 07:54 PM
  4. Data usage on a particular wifi SSID?
    By bhyde in forum Android Apps
    Last Post: 05-19-2014, 05:22 PM
