1. aximtreo's Avatar
    As the title says, I have the Note 8 and I'm having a brain fart on one area. Is there an app that I can download that would allow me to send TEXT messages from this device. I have search the Store but haven't found anything that doesn't require some hoop jumping.
    Any help or recommendations you could make would be most appreciated.
    Aximtreo in Arizona, USA
    06-11-2014 10:04 AM
  2. B. Diddy's Avatar
    There are a few options:
    1. Search for an app, like SMS Text Messaging. You can find others by Googling "send sms from tablet."
    2. Use Google Voice on your tablet. You would need to set up a Google Voice number and let people know to text that number--but you could attach any phone number(s) to your Google Voice number, and therefore have a centralized number. You can't actually make calls from your tablet, but the Google Voice app should let you send SMS.
    3. If you have a landline, it probably supports texting, so check with your phone company. Comcast has an app that allows you to text based on your home landline.
    4. If you just want to send texts, you can usually send it via email. You just need to know how the recipient's wireless provider sets up the email address. For example, on T-Mobile, you can email a text to anyone at [10 digit recipient cell #]@tmomail.net. See this article for more details: Email Text Messages for AT&T, Verizon, T-Mobile, Sprint, Virgin, & more | Hack N Mod
    aximtreo likes this.
    06-11-2014 11:47 AM
  3. aximtreo's Avatar
    Thanks for the suggestions. Settled on Google Voice; works like a charm. Had forgotten I had a google number established a few years ago. Once I signed in to GV, it worked.
    I use to use Groove IP but now it only allows phone calls unless I'm missing something,
    B. Diddy likes this.
    06-11-2014 01:03 PM
  4. bclinger#IM's Avatar
    I use Tablet Talk, works with Bluetooth or Work.
    Sent via my Note 8
    06-12-2014 01:23 AM
  5. Tdc02's Avatar
    Tablet Talk Like bclinge#IM stated above me
    or
    Mighty Text (Use it on PC & Tablet) from my S3 and it work great for text. Everything work fine
    06-12-2014 01:47 PM
  6. bclinger#IM's Avatar
    My concern is privacy, a concept of the mind.
    Sent from my SM-P600 using Tapatalk
    06-13-2014 01:52 AM
  7. dadathepanda's Avatar
    If you have Verizon, there is an app that allows for sms on your tablet, PC and phone. I use it and like it. Also, Samsung released an app called SideSync 3.0 which let's you sync your Samsung phone to your tablet and/or PC therefore giving you access to your phone through your other device
    The panda has spoken
    06-13-2014 12:55 PM
  1. samsung galaxy note 10.1 not working
    By Dania Ayad in forum Samsung Galaxy Note 10.1
    Last Post: 03-09-2015, 06:46 AM
  2. Replies: 11
    Last Post: 06-23-2014, 08:58 PM
  3. Unique "stuck in recovery" issue with samsung galaxy exhibit t599
    By cynthetism in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-11-2014, 09:32 AM
  4. Note 3 USB Issue
    By Madbrood in forum Samsung Galaxy Note 3
    Last Post: 06-11-2014, 03:19 AM
