1. aaimbrogno's Avatar
    I'm torn about which tablet I should get, because I really want a small one, I really want the notetaking capabilities of the note, but I love the AMOLED screen of the Galaxy tab S! I also like how the S lets you have two apps open at once and you can drag and drop things.
    So my question is, when you update your note 8.0 to KitKat, does it give you the capability to do this with the software change? I noticed that the new version of the note 10.1 and the S both have the ability to do it and they're both on KitKat so maybe it's the software.
    Thanks
    07-14-2014 01:55 PM
  2. ehosey2's Avatar
    The Note 8.0 has multi-window capabilities with Jellly Bean.
    07-14-2014 02:40 PM
  3. aaimbrogno's Avatar
    Sweet thanks!
    Sent from my XT1060 using AC Forums mobile app
    07-14-2014 02:48 PM
  4. ehosey2's Avatar
    The Note 8.0 is a very capable tablet even with all the new ones out. I have found nothing to replace it so far. A new version like the Tab Pro 8.4 but with the S-Pen and its software would certainly entice me to upgrade, but that is another discussion.
    07-14-2014 03:24 PM
  1. [FREEMIUM]HandWrite Pro Note and Draw
    By stefoster in forum Tablet Apps
    Last Post: 11-16-2016, 03:50 AM
  2. Replies: 10
    Last Post: 03-10-2015, 10:23 AM
  3. HTC one x wont fully turn on and keeps restarting
    Last Post: 09-03-2014, 01:58 AM
  4. sound recorder and basic music player
    By Emmy Holloway in forum AT&T ATRIX Forums
    Last Post: 07-14-2014, 12:10 PM
  5. Lg G3 vs Z2 vs Note 4 and Z3
    By longsightdon in forum Ask a Question
    Last Post: 07-14-2014, 11:42 AM
