Noticed the following compared to my note 4:
Battery drains so much faster.
Gets hot compares to note 4
you have a Note 4 and Note Edge? Why? Are you comparing them?
Do both units run the same functions during battery test, such as GPS/BT/WiFi off or on, video use and other such settings?
I first got the note 4 when it came out. Why? Cause I'm a tech nut!! Plus the edge didn't have a release date. So I got the edge and sending my note 4 under jump back. I am running both the same way and same apps.
For sure the battery drains much faster on edge.
A couple of days ago, I would have said the Note 4 battery performance was substantially better than the Edge. But now it seems like my Edge is starting to keep up to wife's Note 4 with equal use. The Note 4 might still have a slight "edge" but it has gotten closer as the Edge battery has cycled more and more
Sent via the Samsung Galaxy Note® Edge, an AT&T 4G LTE smartphone
