I love my flip case too. Das and Chris, how do you like your circles? I read and saw many reviews where people complain that they fall off of your ear. Have you guys notice same problem? Also, do you have to use that neck choker thingy to carry the weight of the back piece? Please share your experience.
I have owned the Circle for two weeks now and it works really well. The ear buds falling out has not been my experience. They stay in pretty good, but you do have to ensure you select the correct size for your ears. One other thing I noticed after two days of use is that I had the gels in wrong so it's important to make sure the gels are installed properly.
The neck guards are actually quite comfortable to me. I forget I have them on, and I wear my Circle everyday, all day.
The only negative, and it's a fairly small one, is that the headphones have no way of laying flat around my neck. The earbuds stick out when resting. It's not that big of a deal, and from a design standpoint I can't think of anyway to remedy it, but that would be the only negative.
They have really made my life easier.
