I'm undecided. Note Edge or Note 4? Does anyone have a better battery life or performance than the other?
Hmm if you want a phone that looks like all other phones, then go for the Note 4, If you want a unique phone, with the power of a Note 4, then go for the edge. The 4 has a bigger battery, but the Edge panel has so many advantages over the other phones, it is Apple-like to buy the 4. Playing a game and someone has the nerve to bother you? On the regular type phones you need to stop the game and answer it or ignore it by dropping down the notification bar, but on the Edge, it shows up on your edge panel, where you can either answer it or ignore it without stopping the game. Or anything else you are using. Doing something on one app, and decide you need to open another app? Well on the 4 you would need to go back to the home screen and start that app, then you can go back and forth from the "recent tab" On the Edge, all you need to do is slide your finger on the panel and hit the new app. That is just a few advantages.. As far as battery is concerned, buy a spare. But with Quick charge, you can charge to full in a very short time.
Buying a note 4 is apple like? How do you figure? I had the note edge. And yes while it's cool, it was not all that inpressive. When I'm doing something on my note 4, I have a small pop up for calls and texts. No bother. When I need to switch between apps I have to hit one button.
Yes the edge panel is cool. But for me at least I do not believe in having to carry a spare battery. The edge panel does not outweigh my need for a battery that can call all day with out needing a charge. Also the screen size while not a big deal is smaller. For what I do with my phone, the note edge was not for me.
May The note 4's be with you
Thank you to all. You made my decision easy.
I had the note edge for a while. While it was cool, I traded it for a note 4. The battery on the note 4 is so much better. I have certain things I do on my phone in the morning and on the way to work. On my note edge after waking up at 5am and doing my thing then getting to work I would be at 69% from 100%. On my note 4 doing EXACTLY the same thing I am at 86% from 100. By the end of the day on my note 4 I'm at 29%. On my note edge I would have to charge it at least once. I am not at a desk or in my car at work so charging during the day is a very big inconvenience to me. I can use my note 4 without any concerns all day. Streaming music, Google maps, news, snote, action memo and camera. I also noticed alot of lag on the note edge. My note 4 runs smooth.
I may try the next generation of the note edge if they make one, but for now I'm sticking to my Note 4. I have had every model of the note from its first generation, including the edge. I have had EVERY flagship phone from all manufacturers on many different carriers. And the Note 4 is by far the absolute best phone I have ever used. It is so advanced and so useful, I do not use a laptop at work or home. I can complete every task I have to do for work on this phone. From signing documents to scanning and faxing approvals to doing safety walk throughs while taking pictures of violations, marking the pics with the spen and then sending them to department heads. Doing this on my note edge would require me to carry a spare battery or charge throughout the day. I refuse to have to buy am extra battery for my phones.
The note 4 is all you need man, don't waste your money on the note edge. Yes, it looks cool, but to be honest, if battery and smooth performance are important to you, stick with the note 4.
I remember you being a huge fan of the Edge and stating that you were able to charge at work, so battery life wasn't an issue. I wondered where you had gone. I think it was you that started the thread challenging folks who thought the edge was a gimmicks to explain why.
I did the opposite of you. Went from Note 4 to the Edge and don't regret it at all! So glad Samsung released two great Notes!
but the note 4 to me is more of a powerhouse.
I bought my TMobile Note Edge a week ago, but will return it tomorrow, and will keep my Note 4 I got on day one. To me, my Gear S really enhances my Note 4 to my liking and idea of convenience, so I find the Note Edge unique features unnecessary and redundant. Plus, the Note 4 has a noticeable longer screen, and the battery life seems better too.
