Hi all,
The ringtone settings of my wife Node Edge is jumping back to "Over the Horizon" after every reboot or after an incoming call.
I tried to change it to one of the other default ringtones of Samsung, but after a reboot the ringtone is set back to "Over the Horizon".
I also tried using a custom ringtone without any luck.
I removed the SD card, change the ringtone ... also without any luck
Can anyone help me to fix this issue without a factory reset?
Btw. I have the same phone and I don't have any problem with changing the ringtone on my Note Edge
Specs
Samsung Note Edge
OS 4.4.4
Your help is really appreciated
Specs
Samsung Note Edge
OS 4.4.4
