Which OS do you think has the better battery for the note edge, Kit Kat or lollipop I am currently on KitKat but I don't want to update if it makes the battery worse if you think it makes the battery worse is it worth updating?
Update the device. I'm not sure which model/carrier you are using, but there are very important security updates that make accepting Lollipop that much more important: T-Mobile Galaxy Note 4 and Note Edge receiving Stagefright fix [Update: Galaxy S5, too] | Android CentralWhich OS do you think has the better battery for the note edge, Kit Kat or lollipop I am currently on KitKat but I don't want to update if it makes the battery worse if you think it makes the battery worse is it worth updating?
