1. Rackstraw's Avatar
    What's the latest? Can I unlock my Verizon NotePro for use on T-Mobile?
    04-26-2014 02:00 AM
  2. 05GT's Avatar
    Have you tried putting in a T-Mobile sim card? Aren't all Verizon devices GSM unlocked?
    06-27-2014 06:36 AM
  3. James Fausnaught's Avatar
    Rackstraw.....Have you made any progress in unlocking your Verizon Samsung NotePro 12.2 to use on T-mobiles network?
    06-27-2014 09:19 AM
  4. Vinnces's Avatar
    Would also like to know if it can be unlocked. Tried using a sim from Ptel Mobile and I can't get it to work.
    06-28-2014 07:05 PM
  5. Rackstraw's Avatar
    Nope, no news! Same as with Vinnces above, simply putting in the T-Mobile SIM card does not work. Also tried three repair stores, so far, none of which yielded any way to unlock this NotePro.
    07-06-2014 07:32 PM
  6. Jeremy B2's Avatar
    Other then slow international speeds the device is fully unlocked to any carrier. 3 repair stores and not one of them simply changed the apn settings to tmobile?
    1. Insert sim of carrier.
    2. change apn to that carrier (i just added to the list so i can switch between more than one)
    3. use internet and enjoy
    07-15-2014 02:57 PM
  7. Leonardo Piacenti's Avatar
    Dear all, thanks for this forum..
    Now my note tab 12 verizon is working with my carrier Hug in italy.
    Just a question... how can I make call? I don't see the icon to open the dyaler......
    Any help?
    Thanks
    Sameet Raj likes this.
    09-20-2014 09:14 AM
  8. Sameet Raj's Avatar
    Any help?
    Thanks
    10-20-2015 09:45 AM
  9. Sameet Raj's Avatar
    Hey, how did u get the update?
    10-20-2015 09:46 AM
  10. Sameet Raj's Avatar
    Any help?
    Thanks
    10-20-2015 11:18 AM
  11. Sameet Raj's Avatar
    I have Samsung galaxy note pro 12.2 Verizon kindly guide me. I wanna update it to lollipop.
    10-20-2015 11:20 AM
  12. Jumeck Rafeal1's Avatar
    11-22-2015 05:09 PM
  13. Jumeck Rafeal1's Avatar
    The only way I was able to upgrade to Lollipop was through my Surface Windows 10 PC. To do so you must download the Samsung connect software for Windows, and the drivers so your PC recognizes and communicates with the Verizon Note 12.2. Once set up, use the Windows interface to check for available tablet upgrades, and Lollipop 5.1 is instantly found. Once you've clicked to accept the upgrade your PC does all the work of upgrading for you. Also, If you have Outlook installed on your note tablet, the software can also transfer and set up Outlook with all the email accounts you use on your computer, and the Windows program allows you to backup your tablets apps and files in case you ever need to do a complete system restore.
    11-22-2015 05:25 PM
  1. My modification of Note 3 S-View case to show LED
    By jpr in forum Samsung Galaxy Note 3
    Last Post: 01-27-2015, 07:25 PM
  2. Who is NOT Updating to 4.4.2 on the Droid DNA?
    By xtcFlash in forum Verizon Droid DNA
    Last Post: 05-02-2014, 04:12 PM
  3. What are your thoughts about the Sony Xperia Z2 tablet?
    By petvas72 in forum General News & Discussion
    Last Post: 04-26-2014, 02:50 PM
  4. Rooting Samsung Galaxy Player 5-inch
    By Rackstraw in forum General Android Device Chat
    Last Post: 04-26-2014, 01:15 PM
  5. Samsung warranty outside the US - Verizon phone
    By xxtraloud in forum Samsung Galaxy S4
    Last Post: 04-26-2014, 12:33 AM
