Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Like Tree5Likes
  1. #26
    muzzy996's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: My case/cover causes a strange problem.
    Why fault the tablet, seems to me the fault lies in the case . . improper placement of the magnet and possibly incorrect rotation of the magnet (polarity).
    It's highly unlikely your tablet has a improperly installed sensor given these things are mass produced.
  2. #27
    von13nie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you so much for your post. I found the magnet on the front of the cover by using a paperclip and then I glued a coin over it. This coin is magnetic, it doesn't work if the coin is not magnetic. Your post was very useful.Click image for larger version.
ID:	166951 Problem fixed.
  3. #28
    naeemmll4's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    just close the sensors by sticking a tape on.back side of flip cover there r 2 or 3 sensors
    it work with my note 3 Click image for larger version.
  4. #29
    Sufyan Samad's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Had the same issue with samsung tab 3.. resolved by removing magnet from backside of case cover.... this magnets r used to support the case cover as a stand
  5. #30
    dexterouz's Avatar
    Posts
    Global Posts
    82 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    YES! YES! Thank you so much. I never used it and forgot about the 'Smart-cover option' from settings. Bless you!
  1. [APP-FREE] My Data Keeper
    By Ihor Chornyy in forum Android Apps
    Last Post: 10-17-2015, 09:12 AM
  2. How do I transfer epubs or ebooks to my Galaxy tab3 from my PC
    By D1ckyd00 in forum Samsung Galaxy Tab 3
    Last Post: 03-15-2015, 02:14 AM
  3. Replies: 30
    Last Post: 04-20-2014, 04:30 AM
  4. Rooted my Virgin LG Optimus F3
    By CHELKO in forum LG Optimus Series
    Last Post: 03-07-2014, 06:58 PM
  5. my phone problems..
    By Unisauruss Rose in forum Verizon Galaxy Nexus
    Last Post: 02-14-2014, 09:36 PM
