10-13-2014 08:49 PM
  1. tylerj72993's Avatar
    I just got my new Note Pro 12.2, I'm loving everything about it except the face it will not hook up to my mac to transfer files. It is a late 2012 MBP with osx mavericks on it. I've tried installing kies with no luck. Then I uninstalled kies and tried using Android file transfer and it is not recognizing my tablet either. I enabled USB debugging as well. Any ideas??
    02-17-2014 01:21 PM
  2. Kyle535's Avatar
    Do you have the drivers installed? If not your computer won't recognize your device. So if you don't just Google samsung note pro 12.2 driver Download and it should all work out.
    02-17-2014 01:27 PM
  3. tylerj72993's Avatar
    I am unable to find a driver for it. Do you have a link to one? Any other ideas?
    02-17-2014 01:57 PM
  4. Kyle535's Avatar
    Hmm kies, should have installed the drivers too, the only other advice I would have is to check to make sure the chord and USB port work.
    02-17-2014 08:19 PM
  5. Banefire's Avatar
    You need to load Android File Transfer app. I used it for my Nexus 10 and now that I have the Note Pro 12.2 I have not had any issue transferring files from my Mac to the tablet. It worked right out of the box and when I added a MicroSD card I could see it on my Mac too.
    02-18-2014 03:09 PM
  6. lcavada's Avatar
    i have done that, but still cannot connect to gnp 12.2.
    any further suggestions ?
    thanks
    03-29-2014 05:12 PM
  7. isitme's Avatar
    with the GNP plugged into the Mac and Kies open. Click Tools and hit update drivers. Mine worked great after that.
    I may have restarted Kies after that and then plugged the GNP in, don't remember.
    03-30-2014 09:23 PM
  8. muzzy996's Avatar
    For what it's worth on my rMBP I find that a USB 2.0 cable works but the stock USB 3.0 cable does not.
    03-30-2014 09:36 PM
  9. vorp's Avatar
    Can anyone else corroborate the connection via Kies with the supplied GNP 12.2 cable?
    I've been unsuccessful. It simply won't see my device.
    I've updated drivers, tried every port, restarted several times, uninstalled, tried Android File Transfer after uninstall.
    Also, switching to Win7 using boot camp it connects fine! My USB ports (and cable) must be fine.
    I'm on Macbook pro running Maverick with my shiny new GNP 12.2
    Thanks for any further thoughts!
    I'm stuck.
    -Len
    08-02-2014 10:20 AM
  10. ParuFrade's Avatar
    Did you find a solution? I am having the same issue! Tried everything.
    10-11-2014 05:03 AM
  11. vorp's Avatar
    Nope. Got a mini-SD card to transfer files when I don't want or to or can't use the internet in some capacity.
    Still would love to see a solution.
    10-11-2014 11:13 AM
  12. PhantomRC's Avatar
    Hi guys,
    I had the same problem until yesterday. My Galaxy Tab 12.2 (SM-P900) was only recognized on my windows laptop but not on my iMac. Both softwares (Android File Transfer & Kies) were were installed with no results until ...
    Late in the evening I found an article about "Developer Mode" and how to set this option on. In this mode you can enable "USB debugging" which I did and after I started "Kies" again, all was OK (you will have to wait a few seconds before the SM-P900 is visible in "Kies".
    To access de "Developer Mode": Settings ->General -> About Service -> tap 7 times on the "Build number" to unlock the developer mode.
    This worked for me.
    Greetings from Belgium
    10-12-2014 04:04 AM
  13. MunteanG's Avatar
    PHANTOMRC is correct.
    I had same problem and spoke with Samsung Representative.
    He walk me through the exact process PhantomRC did.
    10-13-2014 12:18 AM
  14. pduffer's Avatar
    I read about another issue resolved by going into developer mode. Should you leave it in developer mode, or turn it back off when finished?
    10-13-2014 08:49 PM
  1. ODIN failing when trying to root
    By chriscw81 in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-12-2015, 10:38 AM
  2. Replies: 1
    Last Post: 02-22-2014, 10:51 AM
  3. Replies: 2
    Last Post: 02-19-2014, 11:42 AM
  4. mobile data quick button
    By CL Bostian in forum Samsung Galaxy S4
    Last Post: 02-17-2014, 09:15 PM
  5. Replies: 2
    Last Post: 02-17-2014, 12:45 PM
