Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Like Tree4Likes
    mkhall's Avatar
    Posts
    Global Posts
    168 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Replacement Stylus & General Tips
    This is my first Samsung tablet, but it sounds as though plenty of you here in this forum are familiar with the Note and the Tab devices. I have a couple of questions that the AC hive-mind may be able to answer.
    First: I'd like to get a stylus better suited to my huge mitts than the tiny thing included. Anyone have a specific recommendation, or even just a brand to try?
    Second: I am hoping to use this as a third screen while I'm working, pulling in trends and feeds from various sources, and taking advantage of the Magazine UX 4-panel screen. can anyone suggest a technique or an app to pull this off?
    Thanks in advance!
  2. #2
    Kyle535's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Replacement Stylus & General Tips
    For your first part, I don't recommend the hex3 jaja stylus at all but they did come out with a nota which looks more promising but I would definitely try it out at like beat buy before hand because hex3 isn't that great of a company. Not terrible just not up to par.
    For your second part, I'm not really sure what you mean or if I could assist you in that matter. Good luck
    mkhall likes this.
  3. #3
    mickeylittle777's Avatar
    Posts
    Global Posts
    222 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is a bit pricey but I've been using this Samsung stylus on several different tablets for a year and a half now.
    Amazon.com: Samsung Electronics Slate PC Digitizer Pen (AA-DP0NE2B/US): Computers & Accessories
    mkhall and DAS like this.
    mkhall's Avatar
    Posts
    Global Posts
    168 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mickeylittle777 View Post
    Thanks, that's exactly the kind of thing I was looking for. I just ordered it.
  5. #5
    Kyle535's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    +1 I'm probably going to have to get one looks nice!
  6. #6
    Posts
    Global Posts
    222 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mkhall View Post
    I forgot to mention the good stuff guys. 1) the button on the barrel works just like on the sPen so when you click it close to the screen the air pen controls pop up, even with the sPen in the chamber. 2) the rounded ball/cap does work as an eraser
    Kyle535 and mkhall like this.
  7. #7
    Kyle535's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    +10000000000 that is amazing!!! Does it have better/worse sensitivity and precision or is it pretty much the same as the spen?
  8. #8
    Posts
    Global Posts
    222 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kyle535 View Post
    I'm not an artist but I tried the sketchbook app and can tell no difference between the 2. Same goes in using sNote.
    Kyle535 likes this.
  9. #9
    Kyle535's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks!! I'll definitely have to buy one!
  10. #10
    Posts
    Global Posts
    222 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You guys be sure and post back how you like this stylus when you get it. Like I say I've used mine for over a year now and never changed the tip. In fact I don't think it came with replacement tip but I could be mistaken.
  11. Thread Author  Thread Author    #11
    mkhall's Avatar
    Posts
    Global Posts
    168 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just got mine tonight. I haven't played with it too much yet, but I can confirm that it comes with five extra tips and that creepy metal loop for pulling them out.
    Oh, and there's a setting you need to change if you want the Air Control to still appear, even if the built-in stylus is in the silo.
  12. #12
    Posts
    Global Posts
    222 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What setting, I don't remember changing a setting? I could be mistaken but I sure don't remember changing anything.
  13. Thread Author  Thread Author    #13
    mkhall's Avatar
    Posts
    Global Posts
    168 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's under Settings > Controls > S Pen > Turn off pen detection. You need to uncheck that or else the built-in pen's presence will disable the input detection.
    mickeylittle777 likes this.
  14. #14
    Posts
    Global Posts
    222 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep one of those things I did and forgot that I did. It hurts getting old sometimes.
  15. Thread Author  Thread Author    #15
    mkhall's Avatar
    Posts
    Global Posts
    168 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I hear you brother.
  16. #16
    Adoga's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know its a bit late but for others that want a replacement, the ones out there are pretty expensive and are not meant to work well with GNP. I tried bamboo and one other, I had to return them because of precision.
    If you want something badly you might have to do it yourself. Here is what I came up with and it only cost me under 20$ and I didn't have to worry about precision - the cost of an extra original S-Pen and a STABILO pen for labelling CDs. It feels great writing and drawing and looks cute too.
    I personally don't need the stupid buttons so I configured and use the "Button Savior" app to display the S-Pen window whenever I need it. Take a look!
    Jess Shade likes this.
  17. #17
    beh
    beh is offline
    beh's Avatar
    Posts
    Global Posts
    1,413 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    And, of course, for a mere $500 you can have a genuine Mont Blanc stylus for your Samsung device
  18. Thread Author  Thread Author    #18
    mkhall's Avatar
    Posts
    Global Posts
    168 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by beh View Post
    No, for $500 *you* can have a Montblanc stylus! Not this boy...
  19. #19
    Adoga's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Actually, I have spent up to about 250$ trying to find a better pen for my iPad and nothing worked well because it wasn't made for that. You don't want to know what I went through before deciding to go for GNP.
    For me, the pen that came with my GNP is just too thin to write over a longer period, you can guess it's the reason I had to search for a full sized pen. I had ones that ranged from 40$ to 70 $ but it turned out they all had precision problem and moreover, their quality wasn't worth the money, so I had to ask for refund.
    In would rather get myself a spare GNP than to spend it for a stylus pen. Maybe I haven't found any reason for that yet.
    I am very satisfied with what I came up with and no other pen, not even the Mont Blanc can add more usefulness and comfortability to it. Its just right for my hands and just ordinary, that's what I like about it. Now I'm getting the best out of my GNP.
  20. #20
    ClaudiaP's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm pretty late on this but I have this stylus and it works great on my Note 10.1. https://store.wacom.com/us/en/product/CS300UK/
    I haven't tried it on a Note Pro12.2 yet as I've just ordered mine.
    Sorry I guess I should elaborate a bit. it is about the same size as a ball point pen. Any of the Wacom Stylii for Wacon penabled devices will work well and they have a huge assortment now.
  21. #21
    Adoga's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ClaudiaP View Post
    I had that bamboo one too but it had precision problem - about 2mm off the pen tip. The pen is only compatible with galaxy note 10.1 older versions and I gathered that it works well on Surface Pro too.
  22. #22
    ClaudiaP's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OK I see what you are talking about, mine does the same thing unless I hold the pen exactly straight up, if I tilt at all is is off a tiny bit.
    The Note Pro arrived this morning and I have been playing a bit, getting it setup etc. This is one beautiful tablet.
  23. #23
    ClaudiaP's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    On the XDA site there are instructions on how to adjust the pressure sensitivity on the Bamboo stylus, there are two "dials" inside the pen and after popping the cap off you can get to them, one is for pressure the other is for offset.
    I wonder if you couldn't tweak the offset a tiny bit to solve precision problem?
    I have a link to instructions but I don't know if it is ok to post a link to another forum.
  24. #24
    aslondon's Avatar
    Posts
    Global Posts
    64 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Stylus looks just like the one that came with my Surface Pro 2. In fact my surface stylus works great. Button brings up the s pen control panel. It might be cheaper to find a replacement stylus from a surface.
    Al
  25. #25
    Jess Shade's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you should figure out how to make one with an eraser (I hate the stupid button) I use my pro 12.2 to edit photos and sketch, I constantly hit that stupid button. I might have to figure something like this out, you should post a step by step to youtube! Maybe figure out a way to make a retractable pen! Patent this, sell it, make the $$ lol!
  1. Tips for multitasking?
    By nixzero in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 02-22-2014, 11:16 PM
  2. Replies: 4
    Last Post: 02-19-2014, 01:45 PM
  3. Replies: 2
    Last Post: 02-18-2014, 10:35 AM
  4. when will we see the replacement for the droid maxx?
    By lgbalfa in forum Motorola Droid MAXX
    Last Post: 02-17-2014, 01:06 AM
  5. Getting A Nexus 5 Today, any tips?
    By macaroon9 in forum Google Nexus 5
    Last Post: 02-14-2014, 08:35 AM
