Results 1 to 4 of 4
    Default Getting started help and S-Note question.
    First - I am really new to this unit and have not owned a Samsung tablet, so I have a big learning curve ahead of me :-).
    1. Does anyone have any good resources such as posts, sites, blogs, etc... that center around "getting the most out of your note" I don't really need an education on android, but have no experience with the Samsung apps. I have particular interest in S-note. I am an Evernote user and really like the integration... once I get my head wrapped around all the options. I suspect there are good resources out there for the 10.1 that work for well for the 12.2 note as well - in regards to the Samsung Apps. I will check that forum as well.
    2. Specific S-Note question - With the "easy illustration" feature you can quickly add a table which I find useful. I cannot, however, find a way to resize the column width or row height. Can that be done?
    Thanks any advance for any all/help.
    T
  2. #2
    Default Re: Getting started help and S-Note question.
    I can help with # 2. Tap on the lasso tool and then tap on the top line intersection point and it will select the table for editing. Then you can drag any point to make the table any size you want it to be. Here is a screenshot.
    Attached Thumbnails Attached Thumbnails Getting started help and S-Note question.-screenshots_2014-03-01-11-50-20.jpg
    Thanks - I must be doing some thing wrong.... I can select the whole table as you have, but tapping the point where you have it circled does nothing. To be clear, I am not trying to resize the whole table, just the widths and heights of the individual columns and rows.
    When I tap on the circle spot you show - it simply moves the entire table and does not resize the column.
    Thanks again - I must be doing some thing wrong...
    T
  4. #4
    No what I gave you only controls the entire table. I'm not sure if there is a way to adjust individual columns like in Excel or in Word.
  1. Galaxy S4 Zoom: camera starts randomly
    By hyuma8 in forum Samsung Galaxy S4 Zoom
    Last Post: 02-25-2016, 08:39 AM
  2. Nexus 5: Possible to charge and output via Apple dock?
    By fommil in forum Nexus 5 Accessories
    Last Post: 03-14-2014, 04:27 PM
  3. Facebook video does not work with Wifi. and some other app
    By mousaali in forum Samsung Galaxy Note 3
    Last Post: 03-02-2014, 02:38 PM
  4. S4 I9500 help
    By sayf777 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-01-2014, 04:03 AM
