1. thegame161's Avatar
    For some reason there is no option in the lock screen settings to add widgets. All it has is
    lock screen card
    clock widget options
    shortcuts set on lock screen
    personal message
    owner information
    but no sign of any possible way to add lockscreen widget. Got this from john lewis in UK so don't understand how there is no option there.
    03-02-2014 10:51 PM
  2. dashdashdot's Avatar
    I have the same, and yet a screenshot I found online has a 'multiple widgets' option at the top. I got mine from John Lewis too. Coincidence?
    Sent with love from one of my Samsungs
    03-03-2014 06:46 AM
  3. thegame161's Avatar
    Maybe this version is different to the one Samsung showed off?
    03-03-2014 07:59 AM
  4. Tigershard's Avatar
    I don't have my Note Pro yet, but on my Galaxy S4, if you have a passworded lock screen you cannot add any widgets that would revel personal data or allow access to apps. If I went without a password, I could use widgets such as a quick short-cut to the camera. I prefer security so no lock screen widgets for me.
    03-03-2014 10:05 AM
  5. dashdashdot's Avatar
    Just found this on a Singapore site:
    'You can no longer display mutiple lock screen widgets. This feature is replaced with Lock Screen Card, which while isn't as flexible as widgets, can be turned on in any screen lock mode.'
    03-03-2014 10:10 AM
  6. mickeylittle777's Avatar
    Unfortunately Samsung is going down the road of the "Walled Garden" of Apple by deciding what to give users and what to take away, since they know what is best for us!
    Call it what you want but it is very sad when I could do things on my original Note 10.1 that were left off of my 2014 edition 10.1 and I still cannot do on my Note Pro 12.2. Sure I can pull up apps in multi-windows and now I can even get 4 windows but I can't pin any of them like I could back on the original 10.1.
    Micro SD cards are another huge issue, maybe not for you but Google Micro SD issues and Samsung Galaxy Note for kicks and grins...
    Thank goodness for rooting even though Samsung gave us more "Walled Garden" effects with the 2014 edition called Knox and if you root you trip the Knox counter and thus end your warranty.
    See where they are going...
    03-03-2014 10:59 AM
  7. thegame161's Avatar
    Very odd and annoying as my note 12.2 is my at home tablet i'm not going to have a pin on so would of wanted lockscreen widgets.
    03-03-2014 02:35 PM
  1. no sound on videos
    By joemontana57 in forum Samsung Galaxy S4
    Last Post: 11-20-2014, 01:52 AM
  2. How to get the new samsung software 4.3 emojis on my galaxy S3?
    By Samantha Porter in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-22-2014, 04:49 PM
  3. Galaxy Note 10.1 Folder Delete issue
    By sirsteve1968 in forum Verizon Galaxy S III
    Last Post: 03-25-2014, 05:41 PM
  4. sketchbook gone and cant get it back...
    By RussellEstridge in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-03-2014, 07:36 AM
  5. How to turn off animation when opening apps on 4.3.3
    By executiveg in forum Samsung Galaxy Note 2
    Last Post: 03-03-2014, 01:01 AM
