Results 1 to 11 of 11
    fastcarve's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Where is Remote PC (Verizon)
    I purchased the Verizon version of the Note Pro 12.2 and can't find the Remote PC app. Is there some trick to finding our installing it?
    Any suggestions for a good alternative if the Verizon version excludes Remote PC?
    Thanks.
  2. #2
    bpeter's Avatar
    Posts
    Global Posts
    69 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Where is Remote PC (Verizon)
    I have tried Remote PC without any luck. I found the app in the Samsung online store (free) and loaded to my 12.2. As per the instructions I went (on my desktop) to the “remotepc.rview.com” site, logged in with my Samsung account, and tried to download the desktop software.
    It appears to start the install but after a while, just stops. No installation, no icon on the desktop, no listing when I click Start and then Show All Programs. I tried the install many times; nada.
    Nothing. I got out of IE, went back in, still the same as above.
    I rebooted, and still the same as above.
    I removed it from 12.2 and am also looking for an alternative.
  3. #3
    deaner1029's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've always used logmein the app isn't free but I think it works well. I have yet to try it with my new note pro yet as I just got it yesterday.
  4. #4
    eds817's Avatar
    Posts
    Global Posts
    2,709 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had no success with RemotePC. I'm now using Teamviewer that works great on my 12.2 and Note 2
    Sent from my SAMSUNG-SGH-I317 using Mobile Nations mobile app
    fastcarve likes this.
    fastcarve's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks. I just tried Teamviewer and it seems to do the job.
  6. #6
    Steve Smithers's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What was the app called in the samsung store? I am not seeing it there.
  7. #7
    Nursedad's Avatar
    Posts
    Global Posts
    71 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by eds817 View Post
    Ditto.
    Sent from my SM-P900 using Tapatalk
  8. #8
    eds817's Avatar
    Posts
    Global Posts
    2,709 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tried RemotePC and couldn't get it to work consistently so I switched to Teamviewer.
    fastcarve's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've been using TeamViewer for a couple weeks now and I'm very happy with it. Based on what others are saying, I probably would have switched to it even if the Verizon version was supplied with RemotePC.
  10. #10
    Cobravision's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you don't have a Windows Professional edition and not sure about setting up port forwarding on your router, then TeamViewer is your best option. But if you do have WinPro and know how to set up your router, the Microsoft Remote Desktop app is hands down the best remote program for the Note.
  11. #11
    bill-e's Avatar
    Posts
    Global Posts
    167 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Remote PC is not included with the Verison Note Pro according to the Samsung site.
    Sent from my SM-P905V using Tapatalk
  1. where did my back button go
    By capsfloyd in forum General Help and How To
    Last Post: 12-19-2014, 03:15 AM
  2. Proximity Sensor on Verizon Galaxy S4
    By silvercrank999 in forum Samsung Galaxy S4
    Last Post: 03-24-2014, 04:45 PM
  3. GPS sucks after Kit Kat update (Yes, high accuracy is on)
    By Just_Some_Nobody in forum AT&T LG G2
    Last Post: 03-17-2014, 10:33 PM
  4. Are antivirus apps really necessary anymore?
    By Lecrae116 in forum HTC One M7
    Last Post: 03-07-2014, 12:43 PM
