Results 1 to 6 of 6
    Default My first problem - frozen OS
    I was using my NP12.2 earlier and put it down for a little while. Then I went to use it again but nothing would work. Couldn't swipte in any direction, neither the hard or soft buttons on the front worked. The volume buttons worked, the power button brought up the device options but would not respond to my touch.
    Didn't know how to do are hard restart so I called Samsung and they were able to help me. Hold the power button for 15-20 seconds and it shut off and I was able to restart it. When I asked what might cause this they said sometimes Android acts up. I guess they bad to blame someone.
    It is nice however to be able to call Samsung and get help. I always say there's more to buying a device then just the hardware.
    Sent from my SM-P900 using Mobile Nations mobile app
  2. #2
    Default Re: My first problem - frozen OS
    The usual cause for this is a misbehaving app. Have you installed any new apps in the last couple of days?
    Sent from my SM-P905V using AC Forums mobile app
    Just like any toy I get I try lots of different apps. I wind up deleting many of them and I'm not sure how Android handles uninstalled apps. Is there anything left behind? Now that I have the apps I'm planning on using I might do a master reset this weekend.
  4. #4
    No once the app is gone, it is gone. It is not lie windows. Yes some apps have better code than others. That is why sometimes an app gets updated every couple of days too, where they find lots of bugs.
    eds817 likes this.
  5. #5
    Red face Re: My first problem - frozen OS
    I had same problems. I had no other choices than letting the tablet draining out of battery, charged it and powered on. Now this solution is really helped. The only problem that I have left is the flickering. I tried all but it happens quite often even new software updated. Hope someone can help me to solve this problem.
    Great. Thanks.
  6. #6
    Quote Originally Posted by dzuidzui View Post
    Great. Thanks.
    You should read the thread:" flickering ", no software updates can fix hardware problem which is cracked battery connector.
  1. Play Store: Can I see all my PURCHASED apps?
    By pcguys in forum Google Play Store
    Last Post: 04-25-2014, 11:26 PM
  2. Note 3 camera reset problem
    By Mellissa Harper in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-17-2014, 02:33 PM
  3. AT&T Galaxy S4: Email Sync Problem
    By htcrazy in forum AT&T Samsung Galaxy S4
    Last Post: 03-12-2014, 10:28 PM
  4. WiFi "Authentication problem"
    By Anthony Russo3 in forum General Help and How To
    Last Post: 03-12-2014, 09:41 PM
  5. Note 3 SD card problems
    By just2wikid in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 03-12-2014, 08:05 PM
