1. eds817's Avatar
    It looks better than the picture indicates
    Sent from my SAMSUNG-SGH-I317 using Mobile Nations mobile app
    Attached Thumbnails My 12" in car GPS :)-1394745494772.jpg
    Android.Ninja likes this.
    03-13-2014 04:19 PM
  2. muzzy996's Avatar
    How's battery drain with a car adapter while GPS is running. Is the adapter able to hold up? (assuming you're using a 2-amp one)
    03-13-2014 05:59 PM
  3. SHIVA77's Avatar
    it's so big, it's more like you're riding the tablet, instead of using it as a GPS. By the way, love using my Galaxy Note 2 as GPS, it's insanely good and manageable battery drain, without even being plugged in.
    03-13-2014 06:51 PM
  4. GANote3's Avatar
    What are you using to hold it?
    Sent from my SM-N900V using AC Forums mobile app
    21stNow likes this.
    03-13-2014 08:42 PM
  5. lobobuzz's Avatar
    Sweet setup!
    03-15-2014 11:17 AM
  6. Android.Ninja's Avatar
    What type of Mount are you using for tablet? If you don't mind, could you tell me where you purchased it. I would love to get the same thing for my vehicle. Thanks!
    Developers don't need no stinkin' signature!
    If I've been able to help you, please hit the "Thanks" button.
    03-16-2014 11:43 AM
  7. eds817's Avatar
    It's an Arkon car mount that connects to the bolt on the car seat. I've had it for years. I also have a windshield mount and the heads are interchangeable. You csn find it on Amazon or directly from Arkon.
    http://arkon.com/tablet-accessories/...car-mount.html
    Sent from my SM-P900 using Mobile Nations mobile app
    Android.Ninja and John Ball1 like this.
    03-16-2014 04:41 PM
  8. ccpopham's Avatar
    Thank you for the info.
    Sent from my SM-P905V using AC Forums mobile app
    03-17-2014 05:18 AM
  9. Android.Ninja's Avatar
    Thanks for the info!
    03-17-2014 07:19 AM
  1. music player auto starts on my Gal S4 - please help.
    By coastalcarlson in forum Android 4.4 KitKat
    Last Post: 03-26-2014, 10:35 AM
  2. I've deleted my android operating system on Galaxy Fit. HELP!
    By Alexghe966 in forum General Help and How To
    Last Post: 03-13-2014, 10:46 PM
  3. Is it ok to disable built in apps?
    By Omer San Gabriel in forum Samsung Galaxy S4
    Last Post: 03-13-2014, 10:26 PM
  4. Can I use some apps on WiFi and some on my data?
    By PittsburghJake in forum Motorola Droid Ultra
    Last Post: 03-13-2014, 05:07 PM
  5. view GPS from S4 mini to Galaxy Tab 2.7
    By B45 in forum Samsung Galaxy S4 Mini
    Last Post: 03-13-2014, 03:20 PM
