Results 1 to 4 of 4
    Default Display won't come on - glitchy
    Not quite the flickering I'm reading some users are experiencing, but I got my galaxy note pro 12.2 on 2/17 and in the past couple days the display has been glitching when I try and turn it on. I have to go back and forth from holding the power button to the home button to even get it to respond. Happens like half the time I try and wake it now. I bought it from Best Buy so I'm calling today to try and exchange it.
    Anyone else experience the delayed display, but not quite the screen flickering problem?
  2. #2
    Default Re: Display won't come on - glitchy
    Bought mine at Best Buy on launch day and no issues like that at all. Works great overall!
    Best Buy is telling me to reset it to factory settings. Maybe it has something to do with certain drivers or files...or something. (sigh) I suppose I'd have to reinstall everything anyway, even if they exchanged it.
  4. #4
    Quote Originally Posted by Rosalind Rosario Hartmann View Post
    Sorry if I'm too late with this advice but don't forget to back up your data before you reset your tablet. I have 2-3 apps that don't sync their data to the cloud and a reset without a backup would be like starting over from square 1 with those apps.
    Now as for Best Buy's advice, they are probably correct and more than likely you have downloaded an app that just isn't playing well with your tablet so you will have to be careful when you restore and put everything back on because if you re-install the bad app you will just be bringing the problem right back again.
    If you have any apps that even appear that they maybe a little suspect you can always read/look at the reviews in the Play store and sometimes discover problems right from there.
  1. Date change on pics?
    By ansa82 in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-21-2014, 02:09 PM
  2. Best android on att
    By conan1071 in forum AT&T
    Last Post: 03-17-2014, 03:06 PM
  3. Nexus 7 (2012) Won't turn power on or be read by my computer.
    By SmoothieBlue in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-16-2014, 10:54 AM
  4. HTC ONE stuck on 4.2.2
    By negritocr in forum HTC One Rooting, ROMs & Hacks
    Last Post: 03-15-2014, 11:52 AM
  5. HTC One can't detect the sim card when data connection is turned on
    By Archedi in forum HTC One Google Edition
    Last Post: 03-15-2014, 07:50 AM
