10-23-2014 09:25 PM
28 12
tools
  1. SilverMerlin's Avatar
    Really keen on buying this tablet, I am a very big android fan I work as a trainer and do lots of travelling, it seems ideal for me. However just have a few questions all of which are deal breakers:
    How close to MS powerpoint is the Hancom version - will I have to significantly reformat slides, I want to get away from MS office ASAP!
    Has anyone actually connected the tablet successfully to a VGA projector if so which dongle have you used most projectors are still unfortunately based on VGA but slowly changing to HDMI.
    Would I be able to use the tablet as a whiteboard - using an app to draw a live sketch which is output through a projector?
    I would like to use the some kind of remote clicker with the tablet - is this possible
    Any assistance would be very gratefully received, but particularly interested to hear from anyone that has used this tablet for training course delivery or presentations actually in the wild
    03-18-2014 03:17 AM
  2. ccpopham's Avatar
    I can only answer one of those question, the one about the whiteboard. I use an excellent app called lecture notes which has freehand drawing on it among many of its features. You could use the freehand drawing as a whiteboard. I also not that you need a USB 3 other connector to connect to a projector etc, but as far as trying to see if it works, I have not and have not worked with Hancom's presentation app.
    Sent from my SM-P905V using AC Forums mobile app
    03-18-2014 05:22 AM
  3. SilverMerlin's Avatar
    Thanks, that is really useful it would look much better than using a flip chart.
    As for connecting to a projector It seems pretty easy for one with a HDMI port. I know that there are various third party connectors out there to connect to a VGA projector but it is a little confusing as to what will work and what will not.I can't go to run a training course for a week and I can't connect to the projector - I would get sacked If anyone has actually done this please could you let me know how you did it it is probably the only thing that is stopping me buying this tablet. I imagine this is an important issue for others as this is aimed partly at the professional end of the market.
    03-18-2014 05:41 AM
  4. ccpopham's Avatar
    I did a search for the note III as the note III and note 12 pro use identical internal hardware and I found this which may be what you are looking for:
    03-18-2014 01:21 PM
  5. SilverMerlin's Avatar
    Thanks, that really helpful I think we are making some progress on this one. After doing some more detective work in the you tube film it looks like it is this HDMI to MHL 2.0 (must be 2.0) adapter -
    http://www.amazon.co.uk/Genuine-Samsung-Adapter-SM-T310-GT-N5110/dp/B00IAE6YGC
    One last key issue remaining now connecting to a VGA projector I wonder if this would work but not sure of the quality of the item - Super Short MHL 2.0 to VGA Cable Adapter w/ Extra Audio for Galaxy S4 / Note 3 anyone tried this on a pro 12.2 or similar?
    03-18-2014 05:26 PM
  6. Ion_NotePro's Avatar
    If using HDMI input on the display/projector -can't you use a chrome cast and connect to it wireless? I don't think you need to have any wireless network in place - it just works host to host? I am going to buy a chrome cast soon - but I thought you could mirror with it.
    I am pretty sure the 12.2 has WIFI-Direct - I see my Roku show up all the time as a direct device but have never tried it.
    There must be a way to do this wireless.
    03-19-2014 07:22 AM
  7. muzzy996's Avatar
    Out of the box Chromecast does not do screen mirroring. There is a root hack available for the Nexus 5 but that's about it, I don't think it has been ported over to the devices yet.
    03-19-2014 10:56 AM
  8. jorang's Avatar
    Maybe the "Allshare Cast Dongle EAD-T10" could be used to connect to HDMI?
    I'm still on N8000. Have tried numerous HDMI to VGA adapters with 'no' luck (using both the Allshare Cast Dongle and the EPL-3PHPBEGSTD adapter). Can view a mirror of the screen on the projector, but typically problems with the aspect ratio (usually gets 4:3), and none of the "office" applications available for my device views the powerpoint slide as it should. I have ended up converting to pdf and using the Allshare Cast to HDMI
    04-03-2014 01:54 PM
  9. sruuth's Avatar
    I bought the Samsung MHL 2.0 to HDMI adapter for the Note Pro 12.2 and it works fine. Not sure how to go from HDMI to VGA though :-( Tried a friend's adapter and it didn't work. Was thinking of getter a scaler/converter rather than a cheaper dongle type. I don't need the cheapest unit, but as I want something for projectors I'd still like something portable enough for teaching and research talks. Anybody had success with an HDMI to VGA converter yet on the Note Pro 12.2?
    wintertrader likes this.
    04-11-2014 08:26 PM
  10. onewac's Avatar
    Haven't had any luck with finding a vga connector so far. No one I have talked with is aware of anything that will work at this point. Nothing fits the slot on the 12.2. The only thing is the HDMI connector so far. According to the local samsung rep the samsung HDMI cable is the only one that has something built inside that makes the screen mirroring to work with audio, video etc. Other HDMI work but they don't work with all the features that the 12.2 offers.
    04-11-2014 10:48 PM
  11. sruuth's Avatar
    I bought one of the Cable Matters active HDMI to VGA Male to Female adapters (113056-Black). it works. I notice some scan lines in my setup (using 1024x768 projectors) but it is unlikely to matter or even be noticed in my application. Oddly enough, now I don't seem to be able to use the HDMI on its own to a projector. I may eventually investigate this further, but it isn't of much concern to me right now since I don't have those types of projectors available normally. Both the samsung and the Cable Matter pieces have power in but I don't need to plug them in. The sound also works on my setup.
    Hopefully people put their experiences into this thread. There are likely better solutions to come in the future.
    04-17-2014 02:41 PM
  12. onewac's Avatar
    Curious anyone get the hdmi to vga connection to work? Am wonder if after hooking the hdmi connecter to the 12.2 if you could attach the vga adapter to the end of the hdmi cable then to the projector if that would work?
    04-21-2014 06:03 AM
  13. bill-e's Avatar
    Sruuth, why not just buy one of the pocket projectors and bring your own. Probably not good for lecture halls but project large enough for many conference rooms.
    Sent from My Samsung Note Pro 12.2 SM-P905V using Tapatalk
    04-21-2014 10:10 AM
  14. sruuth's Avatar
    Thanks for the suggestion bill-e. It is tempting to get a projector, but I am satisfied with my solution for my present needs. All the rooms I lecture in have build in projectors so I will use those and the adapters/converters I purchased. Also, I will keep watching this thread to see what other people learn/come up with.
    cclancy45 likes this.
    04-22-2014 02:42 PM
  15. cclancy45's Avatar
    Nice work... i am picking mine up this morning and I had the EXACT same questions. I do pre-sales consulting, living in presentations and most clients only have VGA in. Can't wait to try your solution and never bring my MacBook again lol.
    05-13-2014 08:20 AM
  16. sruuth's Avatar
    I've used mine now for 2 lectures and it has worked perfectly. A few more observations:
    1. The HDMI seem to work fine on an HDMI monitor on its own.
    2. Using VGA projector I need to plug in the sound on the Cable Matters adapter otherwise my setup gives an odd clicking sound on the projector speaker system. If I plug in the sound into the Cable Matters adapter everything works fine and the projector speakers are silent. So even though I have no sound in my application, I needed the Cable Matters adapter with audio to keep my local projector system from clicking. Just a heads up since some of the adapters do not come with audio.
    3. None of the power inputs on the Samsung HDMI or Cable Matters adapter are needed. I lecture for two hours and the battery doesn't get drained much at all over that time period.
    Cheers!
    05-13-2014 10:37 AM
  17. wintertrader's Avatar
    Hello SRUUTH, can you elaborate please on the Samsung MHL 2.0 to HDMI adapter for the Note Pro 12.2 ? Where one can buy it from ? I can't seem to find where that specific adapter can be bought from (if seems to be working based on your experience). I also read that some others i.e.the Rocketfish brand or other imported adapters will not work with the samsung 12.2 tablet. Thanks
    05-13-2014 01:47 PM
  18. sruuth's Avatar
    This one:
    MHL 2.0 HDTV Smart Adapter
    Samsung is IMHO terrible at identifying accessories for their products. I look at the Verizon Galaxy Note 12.2 at the USA site and check there for working accessories. Verizon seems to be more interested in keeping Samsung's web page up to a high standard than Samsung is!
    05-13-2014 02:00 PM
  19. wintertrader's Avatar
    Thanks. I appreciate. I agree with you sometime is confusing to find the info on the Samsung sites.
    05-13-2014 02:05 PM
  20. madaudio's Avatar
    I have a factory standard wifi only Note Pro 12.2". I am wanting to send the display to my 22" widescren HP w2207 computer monitor, which has vga and DVI inputs. Had some success with a digitek mhl to hdmi with a hdmi to DVI adapter, but aspect ratio was not good: looked like a 4:3 display on a widescreen tv. Also, this adapter was a 5-pin mhl with a separate 5-pin to 9 pin adapter supplied, but I found this placed too much strain in the connection to the tablet. Needing an 11-pin mhl to DVI, or 11-pin mhl to hdmi, and maybe then use my hdmi to dvi adaptor, or buy a straight lead hdmi on one end to dvi on the other.
    OR, interested if a hdmi to dvi could be plugged into a google Chromecast dongle to feed the dongle to my HP monitor. That is, Note Pro to chromecast to hdmi-dvi adaptor to monitor? Want to get a wide-screen result to my wide-screen HP monitor. I am in the land of Oz (down under) which has just had the Chromecast put on sale in this country.
    Thanks in advance for any help anyone can offer.
    05-29-2014 02:46 AM
  21. madaudio's Avatar
    Have I frightened everyone away? Sniff.
    Update:bought the Netgear Push2TV 3000, works perfectly to the TV, which is great - no strain on the USB/MHL port with heavy cables and adapters.
    But using it to send to my HP w2207 computer monitor, with a HDMI to DVI adapter, I get an "out of range" message on the monitor: not sure if this is a refresh rate prob, or a screen resolution prob. (Monitor's max screen res is 1680x1050 compared to the Note Pro's 2560 by 1600). Had hoped the monitor would simply default the signal to its native max.
    Would an active HDMI to VGA converter do any better, anyone with tech savvy on this?
    06-26-2014 04:35 AM
  22. muzzy996's Avatar
    Sounds to me like the Push2TV adapter has its own set resolutions that it will support and the monitor doesn't support them. I would think that the adapter would step down to 720p though but wonder if the introduction of the DVI adapter is somehow linked to the Push2TV not recognizing the supported resolutions on the monitor.
    06-26-2014 12:33 PM
  23. madaudio's Avatar
    Maybe I need some sort of video switch box that allows control of the resolution as it is passed through. I had a Digitek box that converted composite video and svideo to VGA and it provided choices for the video out resolution. Even had a remote control!
    Anyone know of such a device? (Main aim of this exercise is to control my pc from the NP via Splashtop or Remote PC with the video output to my computer screen, in a way that avoids the current situation of a long DVI cable crossing the lounge room between computer and monitor)
    I suppose I could just make do with a cable connection between the NP and my monitor but the only one I have tried presented the NP screen in what looked like the equivalent of a 4:3 format on a wide screen, and a little fuzzy. This was a third-party connection that needed an 11-pin to 9-pin adapter. Maybe the genuine Samsung MHL with a DVI or VGA adapter would work better, without the need for the 11-9 pin adapter?
    Or maybe I should look at making my pc widi enabled to connect the pc wirelessly to its own monitor via the Push2TV3000. (I don't think it is at the moment - it is about 3-4 yrs old)
    06-27-2014 11:00 PM
  24. matngkl's Avatar
    Hello everyone. I am new to this thread but the information contained is very important to me! Just one quick question. Has the original problem regarding presenting a presentation wirelessly using a remote control like kind of presenter been solved? I am still trying to find a remote presenter for my classes. Any help out there? Thanks to all in advance!
    06-30-2014 07:10 PM
  25. goodwinod's Avatar
    I have a Push2TV. It works with HDMI, but it won't work with VGA (even with an adapter). I tried and called the company.
    07-05-2014 06:19 PM
28 12
  1. Cool Apps for the Note 3?
    By texter805 in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-18-2014, 11:47 AM
  2. Galaxy S3 Big Problems after MAJ + Hard reset
    By anthobkk in forum Samsung Galaxy S3
    Last Post: 03-18-2014, 11:40 AM
  3. Looking for a scoring app for my pool league
    By Signtist in forum Tablet Apps
    Last Post: 03-18-2014, 01:37 AM
  4. how can i recover messages from samsung galaxy s5?
    By gtrht in forum General News & Discussion
    Last Post: 03-17-2014, 10:31 PM
