Results 1 to 4 of 4
    Fruuk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default S Note compatibility between Note 3 and Note Pro 12.2
    I'm a Note 3 owner and am thinking about getting the Note Pro 12.2 primarily because I'm a big S Note user on the Note 3 but am looking for a bigger screen to take all my notes on.
    Just wondered if anyone knows the answers to the following:
    1. If I create a note using S Note on the smaller screen of the Note 3, will the note scale up nicely on the larger screen of the 12.2, or will it look too big/small (and vice versa)?
    2. What cloud solution should I use to sync notes created using S Note so that they are available on both the Note 3 and Note 12.2?
    Any info greatly appreciated
  2. #2
    PastorDroid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: S Note compatibility between Note 3 and Note Pro 12.2
    I currently use both the note 3 and pro. Scaling has not been an issue and I sync with Evernote.
  3. #3
    bspill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can sync with Evernote or Samsung. One thing I've learned is that if you want to lock a note with a password, you need to sync first and lock it on each device.
  4. #4
    thegame161's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It works perfectly yes
  1. HTC One (M8): Bugs and Defects
    By jphillips1963 in forum HTC One M8
    Last Post: 12-29-2014, 01:30 PM
  2. s note battery drain
    By emad1995 in forum Samsung Galaxy Note 3
    Last Post: 03-31-2014, 10:37 AM
  3. HTC One GPe: AT&T Compatibility!!
    By nokia4life in forum Google Play edition HTC One M8
    Last Post: 03-30-2014, 04:34 PM
  4. Tmobile Note 3 -Hard Reset-Google play auto sync apps back onto phone?
    By Vanessa Lam in forum Samsung Galaxy Note 3
    Last Post: 03-26-2014, 01:52 AM
  5. Hands free issues, and stop the babbling?
    By thebigbry in forum Sprint Samsung Galaxy S4
    Last Post: 03-25-2014, 10:30 PM
