ccpopham
Lecturenotes has not been updated to work with Kitkat yet and cannot right to the SD card. So it has to save to internal memory. To change the storage location in LN, it is in settings under storage and then choose custom and put in the path where you would like the files stored.
You have to manually type in the path. You need to backup your notebooks board and then copy it to the new directory along with all files in the original directory. Once changed to new directory, then choose restore notebooks board.
Sent from my SM-N900V using AC Forums mobile app
