1. bspill's Avatar
    Every day I'm getting two or three reboots. It doesn't matter what app I'm using, the screen just goes black and reboots. I'm hoping it's not a hardware problem. Anyone having the same issue?
    04-05-2014 09:43 AM
  2. Cuzin Eddie's Avatar
    Yes! I am having the same problem!
    04-05-2014 09:49 AM
  3. bill-e's Avatar
    I've only owned mine for 4 days but not a single reboot
    Sent from my SM-P905V using Tapatalk
    04-05-2014 10:27 AM
  4. muzzy996's Avatar
    Not normal, I had my note pro for over a month without a single random reboot and I'm sure I'm not alone. Could be an application crash thats causing a reboot. Only way to know is to uninstall one by one to determine which is misbehaving. Not an easy task when you could have dozens. Other way to go is a factory reset and rebuild your list of installed applications until the problem appears again.
    04-05-2014 12:23 PM
  5. Miami1683's Avatar
    I've had mine since February and not one random reboot. I agree with factory reset and stay over. If it's an app it will show its face
    Sent from my SM-P900 using Tapatalk
    04-05-2014 01:41 PM
  6. GANote3's Avatar
    Probably a bad app.
    Sent from my SM-N900V using AC Forums mobile app
    04-05-2014 08:52 PM
  7. Nychotxxx's Avatar
    Make life easier for yourself -- if you are still in a return window, do so and get another. It's a problem most likely with the hardware and you got a lemon. If you can't return it follow what the others advise and hopefully you'll be lucky. Or not. I've had my SNP 12 for a few weeks and not a reboot.
    04-06-2014 09:42 AM
  1. Anyone reboot today?
    By SiliconFiend in forum Moto X (2013)
    Last Post: 05-19-2014, 05:42 AM
  2. Note 3: Testing my theory on random reboots
    By ShaggyKids in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-06-2014, 01:27 PM
  3. Wi-Fi Dies In Its Sleep, Requiring Reboot To Revive
    By DirkBelig in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-12-2014, 09:59 PM
  4. Phone keeps rebooting
    By Robin Zelders in forum Google / Samsung Galaxy Nexus
    Last Post: 04-02-2014, 10:25 AM
  5. Weird rebooting issue on Galaxy S4
    By benhaube in forum Samsung Galaxy S4
    Last Post: 04-01-2014, 08:03 PM
