1. elvyb's Avatar
    When I open my files it used to show my files on the left
    With a separate sd card under that.
    Showed my music.
    Showed just pictures
    When I open my file it shows all my files. Every file is mixed up all
    Not separate from what I have on micro sd card
    Can anyone help
    04-06-2014 10:29 AM
  2. eds817's Avatar
    When I open My Files I see both the Device Storage and SD Memory Card on the left under folders.
    Sent from my SM-P900 using Mobile Nations mobile app
    Attached Thumbnails Galaxy Note Pro 12.2: micro sd card-1397036241072.jpg
    04-09-2014 05:39 AM
  3. elvyb's Avatar
    I use too now I don't
    This is what I was wanting to know how to put my files back to what you have sd card on left of screen and note pro files also on left of screen
    If anyone can help me I would appreciate it
    04-09-2014 08:55 PM
  4. Grimgrak's Avatar
    Try another card
    04-10-2014 12:12 AM
  5. elvyb's Avatar
    I fixed it had to do a factory reset
    I did see another post on something different. From that post I did see how to get to the boot system.
    I think th a time might have worked.
    04-12-2014 08:19 AM
  6. Ronzdaname's Avatar
    Does the Note 12.2 support the 128gb micro sd card?
    Posted via Android Central App on my GALAXY Note | PRO
    05-04-2014 04:49 PM
  1. Adding memory via Sim card slot
    By djdonnyk in forum Sprint Samsung Galaxy S4
    Last Post: 04-08-2014, 08:19 AM
  2. HTC One (M8): The SD card...why use it?
    By Preformer19 in forum HTC One M8
    Last Post: 04-07-2014, 09:31 AM
  3. New S4 won't show apps on mSD card from previous S2
    By Sammytheorangutan in forum Sprint Samsung Galaxy S4
    Last Post: 04-05-2014, 04:08 PM
  4. hisense sd card fail
    By Shirley Cagle in forum General Help and How To
    Last Post: 04-05-2014, 08:22 AM
  5. Need help partitioning SD Card?
    By Black-Tigress in forum General Help and How To
    Last Post: 04-04-2014, 10:45 PM
