1. John Ball1's Avatar
    Can I connect a SD card reader to my galaxy note pro 12.2 and use the card reader to get files onto the GNP 12.2?
    04-07-2014 08:02 PM
  2. onewac's Avatar
    I would think you can using a micro 2.0 or 3.0 to OTG cable. I am using one with a hard drive that has movies, docs and photos on it and it works just fine. I use the same drive and micro OTG cable for both my note 3 phone and the 12.2 with no problems interchanging.
    04-07-2014 11:34 PM
  3. eds817's Avatar
    I use this one from Samsung
    http://forums.androidcentral.com/e?l...token=Wg40gdlI
    Sent from my SM-P900 using Mobile Nations mobile app
    John Ball1 likes this.
    04-08-2014 12:28 AM
  4. John Ball1's Avatar
    How do I get my GNP to recognize my external device?
    04-08-2014 12:51 PM
  5. Maxt66's Avatar
    Vodool USB 3.0 Card Reader Writer
    https://www.amazon.com/Vodool-Reader-Writer
    08-25-2016 10:12 PM
  6. muzzy996's Avatar
    I use one of these:
    https://www.amazon.com/Transcend-mic...cUvbUpU5368407
    with one of these:
    https://www.amazon.com/Adapter-LDesi...cUvbUpU5368407
    The micro OTG adapter works great in any flash drive I may want to connect to my tablet too.
    When I connect drives using the adapter they just show up as USB storage in my file browser (I'm rooted, have the My Files app disabled and use Solid Explorer instead).
    08-26-2016 12:44 PM
