08-26-2016 05:03 PM
33 12
tools
  1. sdaisy824's Avatar
    Has anyone experience slow charging on the note pro, my charge slow and it's with original charger that came with it. Does anyone know where to get a long cable and that can charge faster.
    04-12-2014 01:56 PM
  2. Fruuk's Avatar
    I believe it's normal for the Note Pro to take a long time to charge on account of its big battery. I tend to give it an overnight charge and I'm good to go for the whole of the next day.
    I would like a longer cable too if anyone knows where to get one.
    sdaisy824 likes this.
    04-12-2014 03:02 PM
  3. GANote3's Avatar
    Amazon carries USB 3.0 cables that work fine for charging. I have a 4ft and 15ft from amazon
    Sent from my SM-N900V using AC Forums mobile app
    Android.Ninja likes this.
    04-12-2014 03:35 PM
  4. eds817's Avatar
    If you are using it while charging it will be slow and if you are below 10 or 15% it won't charge at all if you're using it. I usually put it on the charger at night when I go to bed.
    Sent from my SAMSUNG-SGH-I317 using Mobile Nations mobile app
    04-14-2014 05:16 PM
  5. GANote3's Avatar
    If it is really low, I turn it off all together and charge it
    04-14-2014 05:34 PM
  6. Grimgrak's Avatar
    Something is definitely not right with mine, i turned it off to charge an 8 hours later it's at maybe 70%
    04-20-2014 09:21 AM
  7. blue13x's Avatar
    Basically the wifi version charges slowly. The LTE version has a qualcomm 800 cpu which has the quickcharge function.
    Sent from my SM-N9005 using Tapatalk
    04-22-2014 07:32 PM
  8. eds817's Avatar
    This one isn't BlueTooth but it looks interesting and only $40.
    http://forums.androidcentral.com/e?l...token=jV6W8x_g
    Sent from my SM-P900 using Mobile Nations mobile app
    04-24-2014 05:42 PM
  9. Grimgrak's Avatar
    WTF does that have to do with charging? ^^^
    Kyle535, bpeter and Android.Ninja like this.
    04-25-2014 09:02 AM
  10. Sherylita's Avatar
    I had one that just gave out and wouldn't charge. My 2nd Note Pro is starting to charge really slow and giving me error messages to use my original charger, when I am using it.
    07-17-2014 02:24 AM
  11. Erik Van Gorp's Avatar
    had the same problem after updating to 4.4.2. It only charged when off. When the device was on, it mentioned 'not charging' in the battery status, but in fact it did charge very slowly when the device was not in use, about 5% per hour.
    Also when used, the battery was draining more quickly than before the upgrade.
    This solved it for me:
    - reboot in recovery mode (hold volume up, button and power while booting)
    - clear cache partition
    - reboot.
    Looks like something in the cache is causing the system to consume (almost) more power than is supplied by the adapter...
    10-01-2014 02:39 AM
  12. Tom Dollard's Avatar
    Whoever wrote
    "- reboot in recovery mode (hold volume up, button and power while booting)
    - reboot."
    SEEMS! to have found the solution of not charging when note pro 12.2 is on. I did it and it's now charging even while on....let's see.
    11-01-2014 11:24 AM
  13. Wol747's Avatar
    Mine is doing all sorts of peculiar things - it's only a week old - such as not switching on at all unless I plug it in (then it's showing plenty of charge, so it's not empty) or not charging at all. I left it switched off and on charge all night only to find it only 31% after 12 hours. Looks like another Samsung disaster.....
    11-09-2014 09:19 PM
  14. Wol747's Avatar
    Update: Thankfully all the problems - some of which were intermittent - were on display when I took it into Bing Lee. They organised a replacement and it was with me within 24 hrs; good work from what is known as a box-shifter company!
    The new one seems to work, so far - except that (like the dud one) it will not screen mirror.
    11-14-2014 12:03 AM
  15. bspill's Avatar
    Would using the Fast Charge charger that came with my Note 4 take advantage of quick charge function on my Verizon Note Pro?
    12-10-2014 09:45 AM
  16. muzzy996's Avatar
    No.
    Note 4 has adaptive fast charging which needs a combination of a charger that switches between high and low voltage output to the device AND a device that has the charging circuitry and software internally to handle it. Simply having one of the two will not make it work.
    12-10-2014 11:33 AM
  17. Seamas R's Avatar
    My tablet originally worked well. With the usb 3 and original charger, I could power up from below 50% to full in 3 or 4 hours. Occasionally, if it was not available, I would charge with a regular micro usb. It would charge, but as expected, was very slow.
    Now, any time I try to charge with a usb 3, the unit will charge (per the battery lighting on the home page) maybe for a few minutes and stop. Or it will not charge at all. If I use a micro usb, it charges at the slower rate.
    Thinking it might be a cord problem, purchased both OEM and aftermarket cords. Tried other chargers. No change. Will only occasionally charge on usb 3 for a few minutes if at all. The unit charges consistently, the slow way, with a micro usb.
    OK, now I think it is a problem with the port on the tablet. Purchased new port / ribbon cable, opened unit, and replaced. No change in behavior.
    It is a challenge to keep the unit charged with just the micro usb. Have to be on alert and plug in whenever possible.
    Anybody else run into this and have a possible software or hardware solution?
    01-21-2016 09:44 AM
  18. muzzy996's Avatar
    What's charge time like with the unit turned off? When you replaced the port how did the battery look, any signs of swelling?
    01-21-2016 10:25 AM
  19. Seamas R's Avatar
    Nothing noticeable on the battery. Looks pristine. And if I can get it up to near 100% charge I can get 5-6 hours of heavy use out of it so I don't think it is a battery problem.
    With slow micro usb charging, and unit off, it charges from about 25% to full overnight, about 8 hours. But if I am using it, even when plugged in, charging can't keep up and I slowly lose charge.
    01-21-2016 01:07 PM
  20. Seamas R's Avatar
    I think it may end up being a battery problem after all. As time has gone on, even regular usb charging has glitches. I downloaded the suggested battery monitor. What I see is that I am having problems as the battery gets to about 110 degrees F. I think a safety cuts off charging (although the tablet continues to run). Would be nice if the operating system popped up a message. I would have been able to diagnose almost immediately.
    Does anyone know a source for OEM replacement batteries?I can find some generic or other brand units but am leery of quality and safety issues. Off brand batteries may not have the safeties that are presently preventing a thermal runaway.
    Have tried to find an "official" source through Samsung's Web site but no luck.
    Also, what is the part number for this? I could open the back again to see but I'd like to minimize opening and closing.
    01-24-2016 01:41 PM
  21. Beut's Avatar
    Micro USB or USB 3 cable has no different in charging. The different is data transfer speed of USB 2 and USB 3.
    Use this one to monitor your charging current, it should read 1.7 Amps
    usb current voltage meter | eBay
    I think your problem if not from USB cable or charger, it must be from your cracked battery connector which is very common from this Samsung tablet and others as well.
    Here is USB 3 cable and micro USB cable charging current , there is no differences
    AceHandler likes this.
    02-06-2016 04:58 PM
  22. Seamas R's Avatar
    Strange. Was able to find replacement battery. Thought that solved the problem. For a while.... Charged like new. Faster with usb 3.0 and original charger. Slower with micro usb. Charge symbol came on along with screen message "for faster charging .." Now it again only charges with micro usb. If I use usb 3.0 and original charger (have tried new usb 3.0 cords and bought a new charger with "Adaptive Fast Charging" model EP-TA20JWE. Does not charge AT ALL with usb 3.0. Old battery would spike to 110 deg F while charging. With new battery max just over 100 deg F.
    So I've now replaced the internal usb 3.0 port, battery, usb 3.0 cables and chargers. What am I missing? With the slow charging, battery management over a whole day is tough. I'm constantly plugging in all day because if I get behind on charge, it's hard to catch up.
    There is a mention of cracked battery cables. Any pictures of problem and how to's for fixes?
    This was a "just right" tablet for me until this charging glitch came up.
    02-10-2016 10:52 PM
  23. Beut's Avatar
    You should read the threat " Flickering Screen " , there are plenty of information regarding cracked battery connector.
    I bought a Note Pro for $200 which the owner said it never gets full charge. Resolder the battery connector then it works like new.
    This is an easy fix but most people just think of something else and waste their time for a simple problem.
    02-11-2016 06:42 PM
  24. DennisOS2's Avatar
    - reboot.
    Thanks for the solving the issue of not charging when in use. I've had all the charging issues stated in this thread and tried everything mentioned. Nothing worked. What was really maddening was the OEM charger not keeping up with charge when the tablet was in use. Really hoping your fix works. Any sense of how long before the problem of not being able to keep up with charging returns?
    02-15-2016 12:16 PM
  25. Beut's Avatar
    This issue can easily fix: re solder the battery connector. I had one Note Pro that battery dropped 30% in 10 minutes. Resoldered the battery connector. then the tablet can standby for a whole week without losing much charge.
    02-19-2016 07:47 PM
33 12
  1. Note Pro 12.2: Just picked one up last night have a few questions!
    By iLLusive in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-14-2014, 08:19 PM
  2. Galaxy S5: I made a huge mistake today...
    By thegrants82 in forum Samsung Galaxy S5
    Last Post: 04-14-2014, 04:53 AM
  3. Galaxy S5: Worth it to upgrade from Galaxy S3 ?
    By MeNTaIPaTleNT in forum Samsung Galaxy S5
    Last Post: 04-13-2014, 06:29 AM
  4. Replies: 5
    Last Post: 04-12-2014, 07:11 PM
  5. How To get Internet Access On My Galaxy Gear.
    By Nika Lomtadze in forum Samsung Galaxy Gear
    Last Post: 04-12-2014, 01:41 PM
