1. Ion_NotePro's Avatar
    Hi,
    I would like to have an Ethernet connection to the note pro, preferably Gigabit. I have looked through the forum posts and have read some contradictory information about what really works.
    What Ethernet adapter do you guys have working? With or without USB ports. For my particular need I only need Ethernet, but some may need to replace report.
    I am also confused about usb-to-go. Does that mean I can connect a mini usb connector in the USB 3.0 port and use them? Sorry this is noobie question, but I do not have much experience with USB 3.0.
    Thanks in advance to any/all help.
    04-13-2014 07:33 AM
  2. John Ball1's Avatar
    Www.usbfirewire.com
    04-13-2014 11:07 AM
  3. Ion_NotePro's Avatar
    Thanks John, I see they a have USB 2.0 model - thanks.
    I see that Samsung is going to make an adapter with 2 USB ports and 1 Ethernet jack, but likely not gigabit. Anyone heard of this or is aware if it's availability
    I saw it in this review - Samsung Galaxy Note Pro and Tab Pro hands-on: First look - GSMArena.com
    04-13-2014 04:50 PM
  4. John Ball1's Avatar
    USBFirewire also has an adapter with two USB connectors. When I went to see them they told me they would design and build any cable you want.
    04-13-2014 05:35 PM
  1. A little Question about Android Instagram
    By kai_derek in forum General Help and How To
    Last Post: 04-17-2014, 12:49 PM
  2. Samsung would like to ditch Android and Google....
    By monsieurms in forum Android 4.4 KitKat
    Last Post: 04-14-2014, 08:10 PM
  3. What to be aware of as a new android user
    By McWolf247 in forum Android Security Apps, Tips & Strategies
    Last Post: 04-13-2014, 05:21 AM
  4. How to insert image?
    By mgillespie1981 in forum HTC One M8
    Last Post: 04-13-2014, 05:06 AM
  5. Delete post
    By Greg C in forum Nexus 4 Accessories
    Last Post: 04-13-2014, 12:04 AM
