1. Fruuk's Avatar
    Wondered if anyone was using multi window, and if so, how?
    04-15-2014 05:04 PM
  2. Evilguppy's Avatar
    Easy. Swipe your finger from the right edge of your screen toward left, it will pull out all the apps that work with multi screen. Then drag and drop the ones you want. You can resize as needed. Up to 4 apps at a time.
    04-15-2014 05:35 PM
  3. bill-e's Avatar
    you can either drag and drop which limits you to 4 or you can have one open and then tap the apps and it creates free floating windows. In that case you will have 5....pretty crowded though
    Sent from My Samsung Note Pro 12.2 SM-P905V using Tapatalk
    04-16-2014 02:56 PM
  4. muzzy996's Avatar
    My typical use was to surf the web full screen while having a video playing in a floating window . . . or surfing while chatting with Hangouts in a floating window etc.
    04-17-2014 12:05 AM
  5. TheodoreWagner's Avatar
    While most stock Android ROMs include features that can only be considered bloatware, once and a while a manufacturer comes up with an innovative and useful feature that they include into their OEM products.
    04-17-2014 12:41 AM
  1. Transferring Windows Phone texts/SMS to Android
    By Whosaninja in forum General Help and How To
    Last Post: 01-16-2017, 07:02 PM
  2. MEDIA cpu usage draining battery?
    By uwbadger2010 in forum Samsung Galaxy S5
    Last Post: 08-02-2014, 04:15 AM
  3. Contacts memory usage
    By RMatey in forum Samsung Galaxy S4 Google Edition
    Last Post: 04-26-2014, 05:42 PM
  4. Multitasking with Pen Window!
    By FutureKix in forum Samsung Galaxy Note 3
    Last Post: 04-14-2014, 02:53 PM
  5. Windows 7 don't recognize Samsung S4 mini
    By Ae Jay in forum Samsung Galaxy S4 Mini
    Last Post: 04-12-2014, 05:55 AM
