I loaded a couple mp4 movies onto my SD card and it won't play them. It says can not find application to perform this action. So I thought I'll move them to the device storage because I know they changed something in kitkat that doesn't allow you to save stuff on the SD card. Still they won't play. I can't even get them to show up in doubletwist or in the play movies app. Is there a way to put movies on my SD card and how do I do it? Also what file format do they need to be?
