1. Consulate's Avatar
    Some help would be greatly appreciated.
    Just like the title says, I went to unlock the tablet like I do 500 times a day and 2 seconds after typing in the Pin passcode the tablet reset.
    Thinking nothing of it, because it has randomly reset maybe 5 times since I bought it, I put my Pin back in once it rebooted and it says incorrect, so I try again--Incorrect.
    I know what the Pin is, I did not forget it.
    I am the only one who uses the tablet and did not change the Pin.
    I do not want to factory reset the thing and lose hundreds of pages of handwritten lecture notes.
    I tried to find the answer online but have only seen Skeptics and people telling me I only have one option(To factory reset) which is not an option to me.
    Can anybody help me?
    -Samsung Galaxy Note Pro 12.2 32gb, Verizon Sim, and 64gb sd
    04-16-2014 11:37 PM
  2. iOS Gravity's Avatar
    Isn't there another option to login with a gmail account after you type the password wrong many times?
    04-16-2014 11:48 PM
  3. Consulate's Avatar
    no there isn't.
    Every 5 tries it says "try again in 30 seconds."
    04-16-2014 11:51 PM
  4. onewac's Avatar
    Could this be the work of the heartbleed bug since any device that uses open SSL is affected?
    04-17-2014 12:38 AM
  5. bill-e's Avatar
    happened to me as well. I thought it might be the wifi unlocker app I had installed. In any case, I had to do a factory reset.
    Sent from My Samsung Note Pro 12.2 SM-P905V using Tapatalk
    04-17-2014 08:40 AM
  1. Static on screen of S5
    By RickB68 in forum Samsung Galaxy S5
    Last Post: 05-10-2017, 08:28 PM
  2. Anyone get Drama Mode to work on S5?
    By Dave S54Me in forum Samsung Galaxy S5
    Last Post: 01-21-2016, 10:44 AM
  3. No light on soft keys s5
    By SERBDVB in forum Samsung Galaxy S5
    Last Post: 04-16-2014, 10:54 PM
  4. External SD Storage on HTC One (M8)
    By Frank Pimentel in forum HTC One M8
    Last Post: 04-16-2014, 10:21 PM
  5. Location on Facebook on HTC One M8
    By TheGreatUnknown in forum HTC One M8
    Last Post: 04-16-2014, 09:07 PM
