Results 1 to 7 of 7
    Default Note-Taking on the Note Pro 12.2
    I am looking for a tablet for note-taking and to take to class. I have been looking at the Surface Pro 2 but at this point I prefer the Note Pro 12.2. Has anyone else used the Note Pro 12.2 for college and taking notes in class? I really like to hand write my notes, but I have found they are so much more organized when notes are electronic rather than on paper, which is why I am looking for a tablet instead of a laptop.
  2. #2
    Default Re: Note-Taking on the Note Pro 12.2
    You will like the note 12, the active stylus works great. Papyrus is a good app for notes, but I prefer lecturenotes. I'm not in college, but I do take notes at work and markup odds, etc.
    Sent from my SM-N900V using AC Forums mobile app
  3. #3
    Think you would like the 12.2 over the surface pro 2. I have both and while the surface pro 2 is great because you can use pc programs/apps on it, the screen is smaller and the battery life isn't as good as the 12.2. Weight wise the 12.2 is a bit lighter but they are close enough that may not make a difference. Size wise the surface is smaller so would be a bit easier to pack in smaller bag. Have to say having both compliment each other for their different uses, the surface instead of a regular laptop because of portability and size however the 12.2 really raises the bar for tablets. For your needs as stated, I think the 12.2 would be the better choice as laptop replacement as long as you keep in mind that as an android based OS it has some limitations such as not being able to use pc programs. Most of the pc programs do have a tablet app counterpart so you can accomplish most of the same functions. However it is the best tablet to date that comes closest to being a full laptop replacement.
    I have a micro 3.0 to OTG cable and use a PNY 128GB thumb drive to store stuff in addition to the sd card. I consider that to be essential for storage and is easier to swap out without complications.
    For note taking I really like the 12.2 over any other device I have on any os platform. The larger screen makes it nicer to take notes at meetings, seminars, etc. Sorry my college days are so far back I can't relate! I would second the Papyrus app for note taking over Evernote or the S note app. No experience with lecture notes although it looks like it would be great. Update: I just got the lecture note app and have played with it. It appears to be more feature rich than papyrus which is really nice because it is not complex in tools or operation. I think between papyrus and lecture notes you would really be set for anything your profs throw at you!
    Thanks! I appreciate all of your input
  5. #5
    The note pro makes handwriting really easy. You can rest your entire hand on the screen while writing, only your text will show. It's like using a legal sized pad and pen.
  6. #6
    bill-e's Avatar
    Posts
    Global Posts
    167 Global Posts
    Which Papryus. There's a couple of them.
    Sent from My Samsung Note Pro 12.2 SM-P905V using Tapatalk
  7. #7
    Papyrus Natural Note by Steadfast is the one I use
  1. Replies: 18
    Last Post: 02-15-2016, 12:28 AM
  2. Replies: 21
    Last Post: 01-23-2016, 08:31 AM
  3. Galaxy S5: What settings to take the best pictures?
    By alil25 in forum Samsung Galaxy S5
    Last Post: 02-04-2015, 09:02 AM
  4. Want to use a MIFI on Tab 3
    By kingfisher171 in forum Samsung Galaxy Tab 3
    Last Post: 04-29-2014, 07:05 AM
  5. Um.. Yeah.. Can't get wifi Back On
    By awriternot in forum Samsung Galaxy S5
    Last Post: 04-27-2014, 01:11 PM
