1. fastcarve's Avatar
    I'd really like to take notes on this tablet using something like LectureNotes, but I'm having a problem which is really hampering the usuability of it for this as compared to plain old pencil and paper. I'd like to see if any of you may know how to resolve this, or if I'm alone in experiencing this issue.
    Most of the time when I use LectureNotes the home button becomes completely inoperative. Even after I exit out of LectureNotes, it still doesn't work. Sometimes if I close the app (via the recent apps button) it will eventually start to work again. This makes it cumbersome to go to other apps not already open when I'm using LectureNotes.
    I'm on the Verizon version of the 12.2. Is anyone else experiencing this?
    I'll send a note to the developer, but it may help to know if others have the problem or even know of a fix.
    Thanks.
    04-28-2014 04:21 PM
  2. GANote3's Avatar
    Have not had that issue. Have you cleared the system cache recently?
    Sent from my SM-N900V using AC Forums mobile app
    04-28-2014 04:31 PM
  3. fastcarve's Avatar
    Thanks for the feedback. Yes, I cleared the system cache today and I'm still having the issue intermittently. Something odd is that I've also seen it after a reboot before going into LectureNotes, and then it cleared up (started working) after I opened LectureNotes, at least for the moment.
    As a side note, when this happens the back and recent app buttons only work with the stylus and don't work with my finger. Likewise, the power button won't pull up its regular menu - it can only be used as a restart by holding it in for a while.
    These button issues all come and go together (back, home, recent apps, and power).
    04-28-2014 05:32 PM
  4. GANote3's Avatar
    Here is something to possibly try, back up your settings and notebook board and try Uninstalling the app and see if the problem goes away or not and then try reinstalling the app.
    fastcarve likes this.
    04-28-2014 08:18 PM
  5. acadoid's Avatar
    @fastcarve: That's a rather weird problem that you report, I never heard of anything similar before. LectureNotes is not involved in the handling of the `home (or the `menu) button. This is in difference to the `back button, for which LectureNotes is asked whether it wishes to handle it.
    I did not receive your email concerning this problem.
    Is your device rooted? If so, are you using the stock or a custom ROM?
    04-29-2014 04:03 AM
  6. Freeaz's Avatar
    I have a similar problem and i don't have lecture notes. Sometimes while working the screen turns off and I can't bring it back by pressing the home button and have to press the power button.
    It's a very strange problem and my device is not rooted.
    04-29-2014 05:55 AM
  7. Freeaz's Avatar
    Surprisingly enough a friend of mine who has the samsung galaxy note 3 phone told me he had the same problem where the screen dims and home button does not bring it back.
    is this a hardware problem or software.
    04-29-2014 07:43 AM
  8. fastcarve's Avatar
    [duplicate post]
    04-29-2014 08:21 AM
  9. fastcarve's Avatar
    @acadoid, thanks for your response. I hadn't emailed you yet.
    I'm on a P905V, not rooted. For the moment everything is working perfectly and I plan to actively used it today to see how it does since the issue was intermittent. I removed other apps I installed over the last week in case they were associated with the issue, even though there was a direct correlation with the problem occurring when I would use LectureNotes. I also once again (after deleting other apps) cleared the system cache and the application cache.
    Since doing the above, I have not seen the problem again. I'll see how it does throughout the day today.
    Thanks.
    04-29-2014 08:29 AM
  10. fastcarve's Avatar
    @Freeaz, I've had a problem like you describe since day one with my 12.2, though it is different from what I originally posted about. Occasionally my screen/tablet will go into lock mode (screen goes dim and I have to press the power button to wake it up and then enter my unlock info). When this happens and I unlock the tablet, the home button still works as it normally does.
    It is a little frustrating as it will happen right in the middle of working with the tablet rather than when it is idle.
    04-29-2014 08:36 AM
  11. Grimgrak's Avatar
    Strange I wind up randomly hitting my home button and going into stupid google search all the time. Wish my home button was disabled lol.
    04-29-2014 08:59 AM
  12. GANote3's Avatar
    In your settings do you have smart screen turned on or off?
    04-29-2014 10:01 AM
  13. AndyJ7888's Avatar
    I don't think it has got to do with LectureNotes. Try clearing the main cache. If still doesn't work, maybe hard reset could remedy it.
    Posted via AAJ's NotePro
    04-29-2014 10:03 AM
  14. GANote3's Avatar
    When I had the smart screen on, it caused some strange issuesm
    04-29-2014 11:03 AM
  15. fastcarve's Avatar
    And... the problem returned. Once again it was when I was using LectureNotes. It only lasted a few minutes and then it started working again. I'm stumped. I really don't know for certain if there is something about LectureNotes causing this or if it is a coincidence, but there is a common theme of it starting to happen while I'm using Lecture Notes, and it has yet to first appear when I'm using any other app.
    I've cleared the main cache a few times.
    04-29-2014 11:07 AM
  16. GANote3's Avatar
    What version of Android are you on? The update 4.4.2 is causing several issues.
    04-29-2014 11:09 AM
  17. AndyJ7888's Avatar
    Agreed!... big big issue on SNote stopped working. .
    04-29-2014 11:19 AM
  18. fastcarve's Avatar
    I'm on 4.4.2 as shipped with the Verizon SM-P905V.
    04-29-2014 11:29 AM
  19. Freeaz's Avatar
    @Fastcarve
    You described the problem I have perfectly and I also had it since day one and as I mentioned I saw it with a friend of mine who has a galaxy note 3. Do you think this is a software problem that Samsung can solve with a future update.
    04-30-2014 01:43 AM
  20. acadoid's Avatar
    I am not sure whether this is helpful, but there was a similar issue (display went dark) on the Note 10.1. It occurred when Samsung's AirView was enabled and you used the S-pen for some time (this is why it occurred quite often when using LectureNotes); the problem did not longer occur after you disabled Samsung's AirView.
    04-30-2014 04:04 AM
  21. fastcarve's Avatar
    I'm starting to think the Samsung "smart" book cover is the cause of my NotePro prolems, thanks to the post above.
    I removed the cover and have had pretty much a full day's use without it (between yesterday afternoon and this morning). Since removing the cover, I haven't had a single instance of the screen going dark and into lock mode. That used to happen several times per day.
    Also (since removing the cover) I've had a fair amount of use of LectureNotes and haven't had a single instance of the home button not working. My spectulative guess with the tie to LectureNotes is it could just be the single application where I would apply pressure to the tablet for any sustainable duration, and somehow with the cover flipped behind it I was pushing the cover magnets (or whatever is in it) to the tablet and the issue would appear.
    I don't know if 1+1=2 in this case, but so far so good.
    @Freeaz, are you using a book cover case or some sort of case with that automatically locks or turns off the screen when closed? If so, I'd suggest going without it to see if the problem clears up. I also have a Note 3 with the S-View case and I've never seen the problem on it.
    Thanks all for your suggestions. I'll post an update if anything changes.
    04-30-2014 03:11 PM
  22. GANote3's Avatar
    That makes since with those magnets. If they are strong enough, it will definitely put it to sleep.
    04-30-2014 05:38 PM
  23. AndyJ7888's Avatar
    I had the same issue today. Found out that the cover was the root cause. Now on original Samsung Cover, works perfectly well. Home button works ok now.
    05-05-2014 06:59 AM
  24. ntomlin's Avatar
    Oh wow! I can't believe the cover was causing all my problems! Thanks so much! I never would have figured that out. I had random screen going black and home and soft keys stop working. But now perfect!
    10-13-2014 10:07 PM
  1. Custom os warning and problem with volume key
    By Nicola Stead in forum Samsung Galaxy S4
    Last Post: 05-19-2015, 02:54 PM
  2. KitKat and Tethering
    By Ted Zoller in forum Verizon Samsung Galaxy S4
    Last Post: 04-30-2014, 01:08 PM
  3. Help with a case for the Note 10.1 2014 edtion
    By Lorepie in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-29-2014, 11:16 PM
  4. Deal of the day
    By benhaube in forum Moto X (2013)
    Last Post: 04-28-2014, 05:43 PM
  5. change preview pic in the gallery app?
    By agnoslibertine in forum Samsung Galaxy Note 3
    Last Post: 04-28-2014, 04:04 PM
