1. lkjhbmonlj's Avatar
    I recently was disappointed to find that I cannot connect to open (unsecure) Wi-Fi networks with a confirmation page.
    This happens in airports, hospitals, cafes, etc.
    When I tried with Galaxy Note 3, works as follows:
    Settings -> Wi-Fi
    Find open network, tap.
    A web page comes up in browser requesting confirmation or registration or equivalent action.
    After agreeing to this page, connection to network is complete.
    On my Galaxy Note Pro 12.2:
    Settings -> Wi-Fi
    Status briefly shows as "connecting..."
    Shortly thereafter, status changes to "Saved"
    Connection is NOT completed.
    After nearly 2 hours on the phone, both Verizon and Samsung were unable or unwilling to help.
    Help is most appreciated.
    Thank you.
    Ori
    04-28-2014 09:15 PM
  2. Kelly Burby's Avatar
    Settings -> Wi-Fi
    Settings -> Wi-Fi
    Thank you.
    Ori
    Well, I think the problem is with the router mac filtering in some routers MAC filtering is enabled I think Galaxy Note3 mac address is stored in the router while your Note Pro mac address isn't stored in the router. Why don't you try contacting with the network administrator in this case ???
    04-29-2014 01:20 AM
  3. muzzy996's Avatar
    Hmm. Usually for me a few attempts at hitting a web page in a browser will prompt me for a login and then I'm on my way.
    Sent from my SM-P900 using Tapatalk
    04-29-2014 01:39 AM
  4. bill-e's Avatar
    yea, I intermittantly have that issue with both my Ultrabook and Note Pro so I don't think it is specific to the note pro. Sometimes it takes a while to get thelogin page to come up. When that happens I usually create a bookmark for the next time which always works.
    Sent from My Samsung Note Pro 12.2 SM-P905V using Tapatalk
    04-29-2014 10:12 AM
  5. lkjhbmonlj's Avatar
    muzzy996, bill-e,
    I have tried many times over with no success. I was in the hospital for a few days with only my tablet to keep me company, and no success with getting internet connection. It was tough.
    If the page ever comes up I will follow bill-e's suggestion and bookmark the page.
    I think it is an Android problem because in version 4.2 no problem and 4.4 introduced this problem.
    Is there a way to communicate such problems to Google?
    04-30-2014 12:51 PM
  6. whitetailang's Avatar
    Turn off your pop-up blocker
    11-11-2014 11:59 PM
  7. fatyank's Avatar
    I've had that issue also. If I try with built in (Android) browser I never have problem getting Wifi connection, then I use whatever browser I want.
    11-12-2014 06:41 AM
  8. LEXIJADE's Avatar
    When this happens just go up to the search bar & type in cnn.com u might have to do it twice..but eventually it will bring up the wifi's sign on page
    02-08-2017 07:17 AM
  1. How to stop automatic file download from Web?
    By Lauren Spavelko in forum Samsung Galaxy S4
    Last Post: 07-22-2015, 07:29 AM
  2. Replying to notifications on Gear Fit.
    By XChrisX in forum Samsung Gear Fit 1 & 2
    Last Post: 04-30-2014, 06:35 AM
  3. Fox Fi App update
    By alxarambula in forum Verizon
    Last Post: 04-28-2014, 08:13 PM
  4. Question Following Upgrade To Galaxy S5
    By InfernoxCJC in forum Android 4.4 KitKat
    Last Post: 04-28-2014, 06:16 PM
  5. Odd Note 2 Behaviour - Browser opens on screen lock or sleep
    By Buckot in forum Samsung Galaxy Note 2
    Last Post: 04-28-2014, 05:59 PM
