1. John Ball1's Avatar
    Is the AllShare Cast Wireless Hub*compatible?
    04-30-2014 07:59 PM
  2. thoughthalo's Avatar
    Not sure. But there is no reason for it not to be compatible.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    05-02-2014 09:39 AM
  3. rkirmeier's Avatar
    Certainly should be! Any standard Micracast adapter should also work. I'm using an ActionTec ScreenBeam.
    05-02-2014 02:17 PM
  4. mickeylittle777's Avatar
    It works great unless you root. There is a fix even for those who root but I'm trying to find the Stock Recovery File so I can flash it using Odin. I thought I had it but it is only 7 megs.
    It was the correct file so I am rooted and I still am able to use screen mirroring with my all share cast hub.
    05-03-2014 03:20 PM
  1. Replies: 18
    Last Post: 02-14-2016, 11:28 PM
  2. Allshare Cast Dongle
    By ryansmithwvc in forum Samsung Galaxy Note Pro 12.2
    Last Post: 11-12-2014, 02:16 AM
  3. Galaxy S5: Got my wireless charging s-view flip cover!
    By stan23 in forum Samsung Galaxy S5
    Last Post: 06-16-2014, 07:55 PM
  4. Any ETA on the Wireless Samsung S Charger Kit for the Galaxy S5?
    By felloffthetruck in forum Samsung Galaxy S5
    Last Post: 05-12-2014, 08:09 PM
  5. [VIDEO] Wireless QI Receiver Pad for Samsung Galaxy S5
    By chrisngrod in forum Samsung Galaxy S5 Accessories
    Last Post: 05-04-2014, 01:37 PM
