1. dunamis's Avatar
    Do I need to use the OEM 3.0 USB cable to charge from a computer? I tried using a regular micro USB and it goes into modes and won't charge.
    Sent from my XT1060 using Tapatalk
    05-09-2014 02:03 PM
  2. bill-e's Avatar
    It wont matter if you have either a USB 2 or 3 cable because you will not be able to charge from a computer, not even one with a USB fast charger, because they don't supply enough current for this Tablet. I even tried a powered USB 3 hub and it didn't have enough juice.
    Sent from My Samsung Note Pro 12.2 SM-P905V using Tapatalk
    dunamis likes this.
    05-09-2014 02:50 PM
  3. beh's Avatar
    Interestingly, I have found that my Note Pro 12.2 will not charge on a USB 2 cable (known good and works with every other device I own) even from a 2.1amp output charger. Instead it is drained. Using a USB 3 cable (both the supplies one and one of another brand) the tablet charges very quickly. Has anyone else had this experience?
    05-09-2014 10:40 PM
  4. muzzy996's Avatar
    For me I frequently use a USB 2.0 cable for charging. No issues with charging or charging speed using a 2 amp charger.
    Sent from my SM-P900 using Tapatalk
    beh likes this.
    05-09-2014 11:19 PM
  5. mickeylittle777's Avatar
    I believe if you hook up to a USB port it will trickle charge your tablet but that will be a very slow process. And if you use the tablet while trying this it will definitely show as draining since the charge will be less than the usage.
    05-11-2014 09:05 PM
  1. After using hardwired USB keyboard, Auto Correct gone (Note3)
    By sdean7855 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-09-2014, 10:21 PM
  2. Replies: 7
    Last Post: 05-09-2014, 01:09 PM
  3. Transfer from USB storage to SD card without using a laptop
    By dannienunez in forum AT&T Galaxy S II
    Last Post: 05-08-2014, 10:35 PM
  4. Will it harm playing game while charging?
    By Rajeev Kumar5 in forum Moto X (2013)
    Last Post: 05-08-2014, 10:08 PM
  5. Battery doesn't charge to 100%
    By zahirw in forum HTC One M8
    Last Post: 05-08-2014, 10:05 PM
