1. robbyhaha's Avatar
    Is it possible to split the screen using apps of your choice?
    At the moment it allows me to split the screen using the 19 or so apps that seem to be preset.
    I wanna use some different apps.
    How can you make an app appear on the split screen slide out thing on the Right?
    05-13-2014 03:23 AM
  2. SpookDroid's Avatar
    There's an 'EDIT' button on the bottom of the bar that lets you customize it. However, only a limited number of apps support MultiWindow officially (which is why you only see a handful in the bar).
    But if you're feeling adventurous and really need to have this feature, you can root your device and use one of the many hacks that allow the use of any installed app in MultiWindow and Floating Window modes (but note that since not all apps support this officially, some hiccups might appear or the app might not work properly).
    robbyhaha likes this.
    05-13-2014 04:27 AM
  3. dss2000's Avatar
    One of the other posters suggested this app to increase the number of apps that work with multi-window without having to root and it works well. There are still some that don't work but it expands the range of ones that do to make the tablet much more useful. You need the paid version to really make it useful but well worth it.
    MW-Pen App Enabler
    https://play.google.com/store/apps/d...iwindow.enable
    05-14-2014 04:14 PM
  4. robbyhaha's Avatar
    05-15-2014 05:00 PM
  5. SpookDroid's Avatar
    MW-Pen App Enabler
    I don't like this app because it effectively rips apart the app's APK, inserts the code, re-builds it and then installs it. Why don't I like it? One, the obvious privacy concerns: I know it's supposed to be a 'legit' app, but it's re-building the code; you don't know what it's inserting into it. Two, the re-build screws up the signed app code, therefore, it's no longer recognized by Google Play as a valid installation. What does this mean? NO automatic updates or notifications of an update because as far as Google Play is concerned, it doesn't know which app you have installed.
    05-16-2014 10:50 PM
  1. Replies: 28
    Last Post: 11-09-2016, 08:16 AM
  2. Anyone Having Trouble With The Speech to Text Button?
    By mauiman1959 in forum Samsung Galaxy S5
    Last Post: 06-25-2014, 08:52 PM
  3. Unrooted my phone, but it refuse to do updates
    By kooritsuki in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 06-23-2014, 09:31 PM
  4. moving film to sd card
    By Andy Bird in forum Samsung Galaxy Tab 2
    Last Post: 05-17-2014, 02:14 AM
  5. How to free up storage?
    By JobSteves in forum Android 4.4 KitKat
    Last Post: 05-13-2014, 03:17 AM
