1. lucasbuck's Avatar
    Couple (actually 3) quick questions:
    1) Is the cable and plug for the 12.2 the same as for a Note 3 phone?
    2) Will the same wall wart work for both the 12.2 and the Note 3?
    3) I have a couple spare wall warts from my older Note 10.1 (NOT the 2014, the older one). I know the cable isn't the same, but will the wall wart work with the cable for a 12.2 and Note 3? (Was wondering if I could just use the old ones, or if they were a different voltage or something)
    Thanks!
    05-23-2014 08:45 PM
  2. ccpopham's Avatar
    The note 3 and 12 cables and charger are interchangeable. The note 10 is USB 2 and will work, but charging will be much slower.
    Sent from my SM-N900V using AC Forums mobile app
    05-24-2014 06:01 AM
  3. lucasbuck's Avatar
    Thanks for the info!
    05-24-2014 01:07 PM
  4. beh's Avatar
    As long as your charger output is at least 2.0 Amps it doesn't matter whether you use a USB 2.0 or a USB 3.0 cable. That said the USB 3.0 cable seems to finish the last bit of charging to 100% faster according to a simple test reported in these forums for the Note 3 when it first came out.
    05-25-2014 11:45 AM
  1. Car charger amp output
    By dman76 in forum HTC One M8
    Last Post: 05-27-2014, 07:56 PM
  2. Replies: 13
    Last Post: 05-24-2014, 08:30 PM
  3. Charger went out... I have questions...
    By Uncoolsby in forum Samsung Galaxy S5
    Last Post: 05-23-2014, 03:56 PM
  4. Unlock 🔓 question
    By mlbyanks11 in forum AT&T Samsung Galaxy Note 3
    Last Post: 05-23-2014, 06:16 AM
  5. battery voltage question
    By Gavvykinz in forum Samsung Galaxy S5
    Last Post: 05-23-2014, 02:19 AM
