1. Evilguppy's Avatar
    I have a 32 GB LTE Verizon Note Pro with a 64 GB micro SD card.
    I just looked in my settings and it appears that everything is stored in my device, hardly anything on the card!
    (It says I have 19 GB left on my device, 59 GB left on my card)
    But I cannot find the place to change that.
    Could anyone please take me step by step to getting everything stored on my card? It's making me nuts...
    06-05-2014 08:02 PM
  2. ddavtian's Avatar
    If you want to move your files (music, video, documents, etc.), use built-in browser to move files. Or use your computer browser when connected to tablet.
    To move apps to external card, go to settings/general/application manager, scroll right to "sd card", select apps to move. Not all apps and not all data can be moved.
    06-05-2014 10:30 PM
  3. muzzy996's Avatar
    I wouldn't expect huge gains by trying to offload a bunch of things to SD . . 19GB free on internal storage sounds pretty good to me actually. I'm at 12GB and I'm not worried . . Definitely though video and music is ok to move over, but personally I'd stay away from moving apps over. Its just me I guess but I dont want the reduction in speed of running apps off of SD.
    06-05-2014 10:51 PM
  4. Evilguppy's Avatar
    Thanks everyone, that did help.
    06-06-2014 12:31 AM
  5. muzzy996's Avatar
    Try diskusage app on Google play or disk storage analyzer. Apps like that help pinpoint programs and folders taking up space.
    Sent from my SM-P900 using Tapatalk
    Evilguppy likes this.
    06-06-2014 01:43 AM
  6. Welsh_John's Avatar
    I have a Samsung Tab 10.1. The spec says it accepts 32 GB micro SD cards but a friend suggested I use a 64 GB card which works. I am now contemplating buying a Samsung Tab 12.2. The spec for this is it takes 64GB cards. Does anyone know if it will actually take 128GB cards?
    Thanks
    John
    07-06-2014 05:39 AM
  7. onewac's Avatar
    I use 128GB cards with no problems. I also use a 2TB ext hard drive with my movies on it.
    07-07-2014 12:56 AM
  8. Welsh_John's Avatar
    Many thanks for your help
    John
    07-07-2014 06:36 AM
  1. HTC One gets stuck on "hTc" screen. please help!
    By android06 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 06-06-2014, 08:21 AM
  2. LG G2 Korea F320 S/K on Cricket?
    By zacaj in forum Other US Carriers
    Last Post: 06-05-2014, 07:20 PM
  3. Email app that works with links in digest email
    By Bob OHara in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-05-2014, 06:34 PM
  4. Air Command on Note 8
    By Cash091 in forum Samsung Galaxy Note 8.0
    Last Post: 06-05-2014, 06:18 PM
  5. Replies: 3
    Last Post: 06-05-2014, 05:50 PM
