1. John Ball1's Avatar
    Recommendations for a windshield or dashboard mount for MY GNP.
    06-14-2014 09:59 PM
  2. ddavtian's Avatar
    I don't have a recommendation, just wondering if it's legal to have a 12' device on windshield.
    06-15-2014 04:16 PM
  3. onewac's Avatar
    I f you type in "12 inch tablet mount for car" on Amazon, there are several that come up. Don't think you can mount in the windshield or dash because of the weight and size. The mounts that come up should be a pretty good alternative if you mount it in the right spot.
    06-15-2014 05:15 PM
  4. treetopsranch's Avatar
    I can't imagine mounting a 12 inch tablet on the dash board. If mounting so that you can see it then it blocks your vision and would be illegal in U.S. If mounting so that it's flat on the dash then you will certainly have problems seeing it.
    06-15-2014 05:50 PM
  5. onewac's Avatar
    Depends on the state if it would be legal or not. May fall into the cell phone texting rules. I would think putting the 12.2 on the dash wouldn't be practical regardless because of it's size, etc. One of those floor mounts would probably be best all the way around. It isn't something I would do because it would just attract attention of the unwanted kind if you left it in the car plus if you get out and have to put it away in the trunk each time, too much trouble and if your car is being watched they would know where you put it. Those mounts tend to be enough of an advertisement in and of it's self.
    06-15-2014 10:24 PM
  1. ERROR on recovery --> E: failed to mount /data (Invalid argument)
    By maidmarian4 in forum AT&T Galaxy S III
    Last Post: 04-04-2017, 02:47 AM
  2. SD Card won't mount on HTC One (M8)
    By nobergan in forum HTC One M8 Accessories
    Last Post: 05-05-2015, 11:55 AM
  3. Car mount that accommodates a case
    Last Post: 06-13-2014, 06:41 PM
  4. USB storage not mounting
    By regor60 in forum HTC One M7
    Last Post: 06-05-2014, 11:32 AM
  5. Note 3 in Defender Case - Bike Mount
    By mark1123 in forum Samsung Galaxy Note 3
    Last Post: 06-03-2014, 04:53 PM
