1. Fishfam4's Avatar
    Quick question: will the S Pen functionality (the semicircle pf features when the button on the S Pen is clicked) work if I change to Nova Launcher?
    If not, I'll buy the Tab Pro 12.2.
    Thanks!
    07-24-2014 06:22 PM
  2. SpookDroid's Avatar
    Yes, it does! As long as you don´t load up a ROM that doesn't have this included, the S-Wheel is available (I think that's what's it's called...can't remember haha)
    goin_nil likes this.
    07-24-2014 06:27 PM
  3. Fishfam4's Avatar
    Thank you, sorry if it was a stupid question. I figured it wouldn't be removed, since you're just changing the GUI, not the TouchWiz source code. Just wanted to be sure, though!
    07-24-2014 06:46 PM
  4. mickeylittle777's Avatar
    And yes as already stated it does work just fine as I'm a Nova user and the semi circle comes up consistently for me.
    07-24-2014 06:52 PM
  5. goin_nil's Avatar
    Glad to hear that as Nova Launcher is likely one of the first apps I'll be installing on my new Note 12.2 tomorrow.
    @mickeylittle777 & @SpookDroid how many rows and columns can you set for the screen grid in Nova Launcher?
    Sent from my SCH-I535 using AC Forums mobile app
    07-24-2014 07:24 PM
  6. SpookDroid's Avatar
    I actually asked the very same question before I got the Note 3 hehe
    Sent from my SM-P600 using AC Forums mobile app
    07-24-2014 08:58 PM
  7. mickeylittle777's Avatar
    I have mine set to 6 rows and 8 columns but you can go higher and just reduce the icon size.
    07-25-2014 06:32 PM
  1. Replies: 10
    Last Post: 08-07-2014, 08:04 PM
  2. Greetings: Very tempted, but a few questions
    By Ricky Babalu in forum LG G3
    Last Post: 07-26-2014, 01:16 AM
  3. Galaxy s3 battery life question
    Last Post: 07-24-2014, 03:35 PM
  4. HTC One M8 Email Question
    Last Post: 07-24-2014, 03:01 PM
  5. Stylus pen wanted for phone, if useable/possible
    By pintree3 in forum Samsung Galaxy Ace
    Last Post: 07-24-2014, 11:10 AM
