1. goin_nil's Avatar
    Charging fully from 1% to 100% takes about 6 hours. See the attached graph.
    Sent from my SM-P900 using AC Forums mobile app
    muzzy996 likes this.
    08-06-2014 10:59 PM
  2. Grimgrak's Avatar
    Mine takes like 8hr
    08-08-2014 01:51 AM
  3. GANote3's Avatar
    It's a big battery. I have a 20000 mAH external pack that takes about 16 hours to fully charge.
    Sent from my SM-P905V using AC Forums mobile app
    08-08-2014 05:36 AM
  4. goin_nil's Avatar
    Mine takes like 8hr
    The 6 hour stat is just when it reaches 100% but, as I've learned from my phone just because it says 100% it might not truly be 100%. So it might take closer to 7 or so. I've never been awake at 5:00 or 6:00 am to check it right when it hits 100%. 😴
    I've read that phones and tablets will slow down charging when they get near 100% and kind of trickle charge the final 2% to 3%. So they bounce between 98% and 100%, charging and not charging so as to not over charge. But, the meter will still read 100% even when it's not truly 100%.
    My phone has to sit @100% for 2 hours after to truly charge to 100% (ie when the phone says "I'm full" and shows the battery full icon notification) since I have an extended battery (ZeroLemon 7000mAh).
    08-08-2014 03:21 PM
  1. Replies: 89
    Last Post: 08-19-2014, 10:47 AM
  2. Battery life is great, 64 hours on a single charge
    By goin_nil in forum Samsung Galaxy Note Pro 12.2
    Last Post: 08-08-2014, 03:23 PM
  3. Replies: 3
    Last Post: 08-07-2014, 11:57 AM
  4. Nexus 5 Charger gets hot when charging
    By digitLIX in forum Google Nexus 5
    Last Post: 08-06-2014, 10:33 PM
  5. Nexus 7 won't charge
    Last Post: 08-06-2014, 09:41 PM
