1. treetopsranch's Avatar
    For some reason when I power up, it does not go to my home screen. Do you know what causes that?
    08-20-2014 02:31 PM
  2. acejavelin's Avatar
    It should not go to the home screen, it should go to the lock/security screen... what are you getting when you power up?
    Also, are you talking about booting up from a power off state, or waking it up from sleep mode?
    08-20-2014 03:35 PM
  3. treetopsranch's Avatar
    I probably mean the Lock/security screen. Although I don't have it locked. So it's the generic screen it used to go to when powering up from power off state. The one with the weather app and some app logos. The screen you get when in an app and you hit the middle button. (I call it my home screen) I must have changed a setting somewhere. It's going to the 3rd screen on power up only. It's being charged now so I can't post a photo yet.
    08-20-2014 06:49 PM
  4. muzzy996's Avatar
    If you pull down the notification shade, click the gear icon to go to settings, tap on device at the top and then tap Lock Screen on the left under Personalization what do you see on the right?
    If lock screen is set to none then you have it disabled. Experiment with those settings.
    Sent from my SM-P900 using Tapatalk
    08-21-2014 12:19 AM
  5. treetopsranch's Avatar
    That didn't work either. But thanks for trying to help.
    08-21-2014 11:13 AM
  6. muzzy996's Avatar
    Sorry that didnt help. Reading post 3 again you are correct that you are in fact referring to your home screen since you're referring to the screen that the tablet returns to when pressing Home.
    Everyone customizes their home screens differently so I'm not sure what particular page you are expecting to get but assuming you're completely stock (not using a custom launcher) try this:
    Press the Home button and then once you're at the home screen use two fingers to pinch in the middle of the screen. This will zoom you out and present you with the pages of home screen that you have. Is the page that you're looking for visible? If so, tap the little house icon at the top of that home screen to make it default. Then press the Home button.
    08-21-2014 01:02 PM
  7. treetopsranch's Avatar
    Well that fixed it. Much thanks Muzzy!
    Mods ought to make that fix a sticky.
    08-21-2014 01:47 PM
  1. Root I9500 on a Mac, 4.4.2
    By leomar91 in forum Samsung Galaxy S4
    Last Post: 08-20-2014, 09:25 PM
  2. lock screen won't turn off
    By Unregistered in forum Ask a Question
    Last Post: 08-20-2014, 04:37 PM
  3. How to increase touchscreen sensitivity on S4 with Silicone screen protector??
    By newandroiduser416 in forum General Help and How To
    Last Post: 08-20-2014, 04:28 PM
  4. Galaxy S4 overheating at logo screen
    By farazk86 in forum Samsung Galaxy S4
    Last Post: 08-20-2014, 01:27 PM
  5. big problem
    By bbmjack in forum Samsung Galaxy S5
    Last Post: 08-20-2014, 01:18 PM
