1. popengchan's Avatar
    Hi guys can any one suggest an OTG cable that can support charging of the android device at the same time? I looked through Amazon and seems like there are hit and misses, not a perfect one as to what I'm looking for.
    Example, I see cables that has 3 ports, 2.0 otg cable to attach to the device, female micro usb 2.0, female 2.0 usb (for attachment of the external device). Sometimes I see the female micro usb is for charging the EXTERNAL device and not the android device (external power for hdd) itself. Sometimes, I see that it only works for usb flash drives and not hard drives. The female micro usb 2.0 never supports a charging of the android device itself.
    Anyone uses an exact cable that I am referring to? Like connecting a full 2TB hard drive to an android phone/tablet to watch movies and charge at the same time?
    Thanks for all the help guys appreciate it.
    08-24-2014 10:14 PM
  2. muzzy996's Avatar
    Saw a similar thread about this on XDA.
    Here's a link:
    Charging while connected | Galaxy Note Pro | XDA Forum
    popengchan likes this.
    08-25-2014 12:57 AM
  3. ChillyGilly's Avatar
    Did you ever find an answer to this problem? I'm currently going through the same ordeal.
    08-12-2015 12:48 PM
  4. madaudio's Avatar
    Haven't found an on-the-go cable that will do the job by itself, but this looks like it could be a neat little workaround. Was suggested as a workaround in another thread with a similar question.
    http://www.amazon.com/RAVPower-Wirel...cUvbUpU4633469
    Also check out this thread:
    http://androidforums.com/threads/hdm...ssible.932658/
    08-24-2015 07:52 PM
  5. Whitak3r's Avatar
    I cant post links, but I'm referring to the DECEC cable.
    Does anyone know if I can charge and stream media at the same time? I'd like to use this on my note pro to watch a movie from my external hdd, and still have it charge at the same time. If not, do ANY of the cables work like that? I noticed this one has a switch, is there any that charge and work in OTG at the same time? Is there a cheap one like this that works like that. I noticed the first one is like fourty bucks.
    Is this compatible with the s6 edge plus?
    Thank you for any and all help!!
    10-06-2015 02:46 AM
  6. madaudio's Avatar
    Through a link in one of the links I previously mentioned I came across this:
    http://lavalink.com/products/samsung...r-tab4-tabpro/
    I have no personal knowledge of whether it really works, or of the reputation of the company. This is not a recommendation, just a suggestion for you to look at and evaluate yourself. But would be very interested in results if you do try it out, or if anybody else has tried it.
    10-06-2015 09:12 PM
  1. Whats the thinnest clear case for the M8?
    By kwitel in forum HTC One M8
    Last Post: 08-25-2014, 10:15 PM
  2. Ant stuck unnder the screen of my Samsung Galaxy 10.1 Tablet
    Last Post: 08-24-2014, 11:18 PM
  3. OTG cables that supports charging at the same time
    By popengchan in forum Samsung Galaxy S5
    Last Post: 08-24-2014, 10:14 PM
  4. OTG Cable that supports charging of the device at the same time
    By popengchan in forum Samsung Galaxy Note 3
    Last Post: 08-24-2014, 10:12 PM
  5. Obtain data from AT&T Samsung Galaxy Note (1st Gen)
    Last Post: 08-24-2014, 09:18 PM
