Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By goin_nil
  • 1 Post By muzzy996
  • 2 Post By lillygirl7
    mkhall's Avatar
    Posts
    Global Posts
    168 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Multi-window and SwiftKey
    I've noticed that SwiftKey seems to confuse the tablet when it's in Multi-window mode. If I'm running an app in one window while typing in another, the typing window loses focus after each keystroke.
    Has anyone else run into something like this?
  2. #2
    goin_nil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Multi-window and SwiftKey
    I see that too. Makes multi window useless if you have to type in one.
    mkhall likes this.
  3. #3
    muzzy996's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yup, I keep coming back to the stock keyboard due to compromises on other keyboards.
    mkhall likes this.
    mkhall's Avatar
    Posts
    Global Posts
    168 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's a drag, as I have SwiftKey well-trained at this point. Thanks for the confirmation that's it's not just me.
  5. #5
    fatyank's Avatar
    Posts
    Global Posts
    406 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    MKHALL can you give an example of which apps you have open and which one you're typing in. I've had multiple apps open and typed in one with no problem. I do use the floating keyboard but I don't think that would make a difference. I'll try to duplicate your issue.
    mkhall's Avatar
    Posts
    Global Posts
    168 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For some reason I didn't see your reply until now.
    I just tried this again. Two windows: Evernote and Hangouts. When I try to type with SwiftKey in either app, it loses focus after a single letter. I'm not using the floating keyboard, but rather the usual docked version.
    Thanks for any suggestions!
  7. #7
    lillygirl7's Avatar
    Posts
    Global Posts
    116 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same problem with SwiftKey and multi window on all of my Samsung devices. I've tried contacting SwiftKey, but cannot get a response. I also cannot find any fix. I just switch my keyboard when I use multiple Window. Kind of a pain, but it only takes 2sec to switch. Maybe if we all start emailing SwiftKey on a daily basis they will do something about it. Also if we all make a 1star review explaining the problem on playstore it will help get their attention. They don't want low play store ratings.
    mkhall and beh like this.
  1. Replies: 4
    Last Post: 12-26-2016, 12:17 PM
  2. Ringtones and notifications alerts.
    By kanesmith41 in forum General News & Discussion
    Last Post: 09-02-2014, 08:39 PM
  3. Replies: 1
    Last Post: 08-31-2014, 03:38 PM
  4. LG G3 : Link ringer and notification
    By artofdesign in forum LG G3
    Last Post: 08-31-2014, 03:14 PM
  5. Galaxy Mega 6.3 I9200 stuck on black screen and vibrating
    By SLAPLimitless in forum Ask a Question
    Last Post: 08-31-2014, 09:57 AM
