Is it possible to use a Bluetooth keyboard with spell check?
coreymcl
217
14
It's been a few months since I last tried to find an answer to this question.
Has anybody found a way to still have Spell Check working while using a bluetooth keyboard? I'm assuming it's on the tablet itself and not the keyboard brand that I'm using to prevents this from working. But for the record I have the Logitech bluetooth keyboard for the 12.2.
Thanks for the assistance
Re: Bluetooth keyboard with spell check
I have this same problem too... been looking for an answer since the day I got my Samsung Galaxy Note Pro with a logitech bluetooth keyboard... I can seem to find nothing
Try Swiftkey keyboard. you can activate the bluetooth keyboard option in the settings, it maintains the spell check without having an on screen keyboard.
I am actually using that right now.
However, the reason I ran into this post was because I am looking for a solution to this:
SwiftKey is set as the default keyboard on my tablet, but every time my bt keyboard reconnects the standard on screen keyboard is started and I can't get it to pop down. I have to reelected my input method every time.
I would appreciate it if you let me know if you run into this problem/find a solution.
Also Do let me know how swiftkey works for you.
Appreciate your suggestion (Swiftkey). I installed it and it works great. Thanks
For your problem, try FN+RightAlt key to pop up/down the on screen keyboard. Works with Note Pro 12.2 and Logitech Pro Keyboard.
So weird - I had the opposite problem, I couldn't get the predictive/spell correct to turn off! I went to Vegas and brought along my Note PRO 12.2 & its Samsung BT keyboard (GREAT combination btw - the keyboard completely protects the screen and fits the tablet when set up perfectly). I keep a daily journal and decided to use Samsung's Hancom Office (I mean it looks SO Microsoft ;-) ). Every time I typed a capital letter, the cursor position jumps in front of the cap (to the left) and then starts typing the rest of the word/sentence. The only solution I could figure out was to press the right arrow key after typing every capital letter (the only time this didn't happen was when typing a second capital letter after the first one, I.E. WAX). So annoying that I even contacted Hancom/Samsung help - well, they suggested turning off the predictive text settings (did that, duh!) then they said they wanted me to send them a copy of my journal - yeah, that's gonna happen soon as NEVER. Retarded it was I tells you...other than that I had a great time, thanks for asking.:D
I had this same problem when using Swiftkey as the default soft keyboard and Hancom. Gave up and just removed Swiftkey, bluetooth keyboard works fine now. Swiftkey was only a problem with Hancom.
slackingfred
