My Note Pro had the problem of the screen flickering because of the bad (weak) battery connection on the motherboard. I bought a new motherboard and replaced it. The Tablet boots into a service mode to check to make sure everything is working... speakers, camera, WiFi, etc. Also has an icon on the desktop that says "Factory EMI". The problem I am having is that I cannot exit this service mode to get to the Normal Android operating system. Also, my tablet was running Android 5.0 (with old motherboard), and in this service mode (new motherboard) says it is running Android 4.2.2. So I am guessing the Android OS is part of the motherboard and the 32GB of memory is not?
Anyway, my problem is not being able to exit this service mode. Can anyone help?
