1. DennisOS2's Avatar
    I actually service three different Samsung tablets; NP12.2, NP 10.1 and a new S3. Just recently we've had a situation where it would have been convenient printing directly to our printer (Epson 4550 multi-function with WiFi ). All are connected to the same WiFi system. We have all the Epson printing apps. We've never attempted printing from a tablet, so I was wondering if it really works. Is there a trick to it? Is there something people forget to check. Eventually, I can see all the tablets printing to the Epson.
    Any suggestions or tips? Thanks in advance.
    04-20-2017 05:04 PM
  2. Tim1954's Avatar
    Cant see why not. Open file, find settings /options by tapping the file. You should have the option to print there.. (sometimes look in share to find print option). Once you selected print, the device will search for a printer. You may also have to download the plugin for printer from play Store. Once the device sees the printer you should get options to set up the job....
    04-20-2017 10:18 PM
  3. DennisOS2's Avatar
    Thanks for the info. Just wondering if this was a given or like when old standards were released but the same standard didn't work with all implementations of the standard.:-
    04-21-2017 08:57 AM
  4. Traylaw's Avatar
    To print from your tablet you will need to install a print service for epson printers. Go to setting -> more networks -> printer. Then select add plugins, this will take you to the play store where it lists various printer manufacturers. Once the plugin is installed you will probably need to enable it and let it find your printer
    My wife and I print from our tables and phones all the time.
    If your printer is a multifunction (scanner) you will also need to install the epson app to access the full functionality of you printer.
    Yesterday 09:00 AM
  1. Samsung Gear S3 - Improving GPS Accuracy
    By brucedroid in forum Samsung Gear S3
    Last Post: Yesterday, 01:05 PM
  2. S8+ with Gear VR 2016
    By ReeceF11 in forum Samsung Galaxy S8 & S8+
    Last Post: Yesterday, 01:01 PM
  3. How to wake up my non responding Samsung Galaxy S7 EDGE?
    By mia005 in forum Samsung Galaxy S7 edge
    Last Post: 04-20-2017, 05:33 PM
  4. Replies: 1
  5. Replies: 0
    Last Post: 04-20-2017, 04:10 PM
