Results 1 to 3 of 3
    devoncatt's Avatar
    Posts
    Global Posts
    49 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Note Keeps losing wifi
    I am just curious my new Galaxy note keeps dropping my wifi. It is G wifi not N, my old iPhone 3 GS held it steady, my partners laptop holds it, the dvd player connects to it but the Note keeps defaulting to another wifi that has much less signal strength.
    Any Suggestions?
    Devoncatt
  2. #2
    kwilsonjr's Avatar
    Posts
    Global Posts
    78 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Note Keeps losing wifi
    Long press the connection you don't want to use and select 'Forget' - Long press the one you do want to use and select 'Remember' (if it is not already remembered)
  3. #3
    scaots's Avatar
    Posts
    Global Posts
    552 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    stock
    And make sure your settings are not set to automatically connect to open wifi
