Results 1 to 9 of 9
    Default low memory warning keep pop out even after clear
    Whenever I play game, even surfing the internet only, a warning box with highlighted title 'low memory warning ' always pop up. The message mentioned that my memory has been used up more than 90%,and I am asked to clear the memory now. There are two options to choose from, either to clear now or to clear later, I choose clear now. However, it doesn't solve the matter. After a while, the same warning pop out again. I checked my phone ram, I used up about 547mb out of 800mb! My storage memory used up not even half of it! Is there anybody who can help me up with this issue? Thanks for your kindness!
  2. #2
    Default
    Try an app like advanced task killer to help free up some ram.
  3. #3
    Aznflawless's Avatar
    Posts
    ROM
    Ice Cream Sandwich
    Default Re: low memory warning keep pop out even after clear
    Try to reboot your device. Turn it off and on agian.
  4. #4
    What game are you playing? I've been getting it, too, but I'm a little suspicious. The grammar is a little off and the window doesn't look like either Samsung or Android.
  5. #5
  6. #6
    Found it. It's the Go Launcher Task Manager app. Uncheck the low memory warning notification in the app settings.
  7. #7
    Default
    Me too facing the same prob
  8. #8
    It's been a couple of days since I got the message, so I'm willing to declare Go TaskManager as responsible.
  9. #9
    seaa's Avatar
    Posts
    Thanks Dr. Triffid! I signed up to Android Central to thank you for your answer LOL
